      Artboard 1 uses a Reference Canvas. Now what?
      • pentool
      6173
      No, it was just an empty document with a circle and a star in it. I don't seem to be able to recreate it at this point, but when it happens, I will save it.
    • _
      Selecting Paths and Objects
      • _NM_
      3043
      @_NM_ said in Selecting Paths and Objects: It is perplexing when the selected canvas and layer differ. I Welcome to vectorStyler. Yes, the selection in the Layers panel and on the canvas are different. These can be synchronized (Layers panel menu -> Panel Options) if needed. This mode (similar to how it is done in Adobe Illustrator) enables some features between the canvas and Layers panel.
      Collision snap incorrect
      • pentool
      2387
      @pentool Replicated here also, there seems to be a precision issue in this case. I will try to fix this ASAP.
      What's the point of artboard rotation when contents are not rotated but moved?
      • pentool
      4224
      @pentool Yes it is related, but it is a feature. Selecting rotated artboards will rotate to view to align the artboard for editing.
    • Force VS to only allow a specific sublayer shape to be edited?
      4317
      @Boldline Active shape is something else. I think this should be an option of the Node tool, whether to allow selection of other shapes, while a shape is already selected.
    • How Do I Use "Draw Inside" Effectively?
      7243
      @Boldline Here is a Video of another good use for the third example (but remember you need a group, or a dummy group to work this way)
      How to turn off layer drag preview?
      • pentool
      7690
      @pentool said in How to turn off layer drag preview?: Those who want it can turn it on, those who don't, turn it off. This is where the many customizations and settings originate from!
      DOCUMENTATION: No definition for a few Grid menu items
      • pentool
      8483
      I won't rush to say that more complex arrangements with multiple grids are not needed — maybe the developer had something in mind with that and didn't get around to post a tutorial with a specific case where this is needed. In any case, an app can be complex for when complex stuff is needed, as long as the complex parts cannot be enabled by mistake and don't interfere with the expected behavior for basic stuff.
      Snap to Reference Sizes - but how?
      • pentool
      3672
      @VectorStyler Nice!
      Is there a way to transform/rotate shapes but with an offset?
      • pentool
      8157
      @VectorStyler Well, this is at two places. In the Transform > Rotate and Transform > Transform dialogs. I think the value control works (the one where you can either input a number and change with the up/down arrow keys, or it opens as a horizontal bar that you can drag left and right)
      DOCUMENTATION: No "Merging" checkbox for Eraser Tool
      • pentool
      3017
      @pentool Will be fixed, it is the "Join" drop down The documentation needs the major update
      Some Action folders remain open and some get closed after switching panels
      • pentool
      2265
      Why did "Actions" disappear from the Preset Manager's Preset list?
      • pentool
      5687
      @VectorStyler Ah, that's right! That's what it was! I knew I added the actions to the Preset Mgr somehow but I forgot how I did it. SELECTION! You have to select the group! Yes, that's what it was. It's not as obvious because the only indication that the group in the Action panel is selected is that more icons get enabled at the bottom of the panel. And it's easy to overlook. Maybe because I'm using a dark theme...? Will have to see how the light one looks.
      Weird line on hover
      • pentool
      7312
      @pentool There is a bug with composite shapes containing transformed shapes. Can be replicated here also, will try to fix ASAP. As a workaround, convert all (including the lines) into curves before making a composite shape. That will "bake" the transform into the lines.
      Weird preview line after editing a node with the pen tool
      • pentool
      3783
      @pentool said in Weird preview line after editing a node with the pen tool: Once you adjust/edit a node with the pen tool and then want to continue drawing the line, the preview segment will be heavily curved. It should be straight because the last point is a cusp node. Added this to the backlog.
      Contour Tool > Smooth Steps - no changes
      • pentool
      2057
      @pentool Added this to the backlog, looks like a bug.
      Documentation: No "Dynamic" mode checkbox for Pencil tool in context panel
      • pentool
      2378
      @pentool it is the Eraser checkbox, I will update the documentation.
      UI Theme: "Size:"
      • pentool
      1982
      @pentool Some resource name referencing issue (again), will be fixed ASAP.
    • Weird frame
      4558
      @Ingolf I will try to replicate this.
    • How do I change the color of all text of a certain color?
      3541
      @Boldline Select by shape (and other selection) commands cannot select parts of the text only. I tested this, and here I get all text shapes selected as objects. So only the use of color styles remain for this.
