    • E
      Blend along a path : can objects be shifted vs path ?
      • EricP
      875
      @Li-Xiao thanks for the tip. Yes bending is actually a good idea. I found it easy to control by grouping the path and blended shapes together before applying blending shape effect. Everything stays well connected
      Scaled object copies by 75% are bigger instead smaller when using Randomness.
      1577
      @EricP said in Scaled object copies by 75% are bigger instead smaller when using Randomness.: was this changed in a recent release ? Yes, there were changes here.
      Exporting artboards
      1194
      @Harry said in Exporting artboards: but the list of dragged and dropped artboards is always numbered in order from 1 to, for example, 10 This is because those artboards are not named. The "Artboard 1" name is automatically generated if the name is empty.
    • D
      Image resolution when exporting PDF
      • Dahzee
      537
      @Dahzee There seems to be an issue with this, I opened a bug and will provide a fix for the next built.
      Detail optimization and function enhancement
      • monsterfox
      87
      87
      79615
      @monsterfox said in Detail optimization and function enhancement: However, selecting "Show All" results in the same entry appearing five consecutive times — is this a bug? Yes, this is a bug.
      Could low decay values in spiral tool have a smoother transition ?
      874
      @Subpath I reopened this issue
      Vectorstyler on Linux?
      • Benny
      7158
      @vegenaut said in Vectorstyler on Linux?: I too would love a Linux port! Thanks for the purchase, and I will get to this soon.
    • How do I swap an existing symbol on the artboard with another from list in panel?
      786
      @VectorStyler Sorry, it works somehow but offsets very odd. https://go.screenpal.com/watch/cT6ZIFnbMTr Please, try out the file .. 0_1761311781240_1080x1750-UI-01.vstyler
    • How do I get artboard back to normal
      504
      @Raaskot Update. Found the reason: I had pressed the opt-cmd-G combination Checker Board
    • Blending mode in layer settings / how is this in VS?
      1430
      @MrDixioner I will try fix the previewing issue. But the Transparency panel should also work with the layer selected.
    • Scale the shape WITHOUT scaling the stroke
      1131
      @Raaskot I also have everything working fine by default, meaning I didn't configure anything when I first launched the program. In such cases, deleting the program's settings files is usually recommended, but you could lose all your settings, so the choice is yours.
    • Strange offset paste issue
      677
      @Raaskot said in Strange offset paste issue: I opened a bug on this and will try to fix it.
    • Distorting an imported raster image -- how?
      735
      Ah, very cool. Thanks
    • E
      Is there a "lock children" feature ?
      • EricP
      773
      @VectorStyler thank you !
      Expand Appearance is not documented
      • MrDixioner
      1152
      @MrDixioner always gladly, nice that it was helpful Btw, double left click on a tool icon brings up a little panel where you could change the settings of a tool. Try also different Tools this way.
    • How does Path Eraser Tool work?
      1688
      @Raaskot said in How does Path Eraser Tool work?: I've tried to change all settings to full ("8"), but nothings seems to happen. It is not in the settings. Activate the eraser tool (not the path eraser, but the other one), and set the brush size in the context panel.
    • E
      Moving multiple nodes in a clipping group object?
      • eobet
      1962
      @eobet said in Moving multiple nodes in a clipping group object?: But, the multi selection stroke thickness slider disappearing in isolation mode and turning all strokes into hairline I can still replicate, I tried to replicate this on both Mac and Windows, but it seems to be working here. If you could make a small recording on how you replicate this error, it can help a lot. Thanks!
      Path Brush tool with direct live drawing preview and few smoothing?
      • littbarski
      1058
      @littbarski said in Path Brush tool with direct live drawing preview and few smoothing?: when the program starts it says the trial is expired, I think the previous reset period was in the spring. I will try to reset it for you next week.
    • E
      Rotation goes crazy
      • eobet
      1145
      @eobet said in Rotation goes crazy: Hello! Here is the file, but as I mentioned, once I made "save as copy" and opened it, the issue went away. 0_1760094506577_rotation.vstyler Got it, thanks. I will try to have a fix for this ASAP.
