    • Repeater takes massive amount of resources to do small commands
      5999
      @Subpath said in Repeater takes massive amount of resources to do small commands: The steps that are necessary for this are explained in this tutorial section here, in case you dont remember: I appreciate you sharing all of that again. I will certainly check it out and see what else can be done!
      Paragraph panel
      6585
      @VectorStyler Thanks. I've tested on my two W11 pc & it is the same issue.
    • Shape core-line setting?
      • Ayo
      6863
      @Ayo I'm back to this discussion: Are you requesting a way to change the shape's "core-line" when selected because editing the color of the stroke is more difficult when this colored contour is superimposed over the shape?
    • R
      Crash due to system UI font call.
      • richbyte
      4075
      @richbyte You can use the Console app (from Applications > Utilities) to find the last crash report for VS.
      Expand Stroke Weird Result
      • gotanidea
      4292
      @VectorStyler Thank you Admin
    • Modal Dialogs on Mac
      4310
      The whole "Delete" thing came into play around the same time that Apple started pushing "auto-save": with auto-save, the document is saved automatically and continuously, so there is no concept like "Don't Save" any more at that point. "Delete" makes more sense once you have an auto-saved document and want to get rid of it, but if it was never saved in the first place, then it becomes confusing, and if it was, then it should save automatically anyway, so there is no reason to prompt... the way the whole "auto-save" thing is presented to users was poorly designed in my opinion, particularly as it is mixed in with apps that will and will not use it adding further to the behavioral confusion.
    • What is different about adding a spot color via the artboard tool compared to manually using the plus sign icon in the palette panel?
      5572
      @b77 said in What is different about adding a spot color via the artboard tool compared to manually using the plus sign icon in the palette panel?: Expanded to RGB or CMYK color mode, depending on the document color mode? Expanded to the color mode of the original spot color.
    • How do I view the 'Shape Editing Indicator'?
      • Ayo
      4586
      @VectorStyler These two at least could display the tool name in parentheses, like this: Shape Erasing Style (Trim and Join tool) Shape Editing Indicator (Grid, Super Ellipse, Super Shape tools) Btw, the last one is a slider, so a better description could be: Shape Editing Slider (Grid, Super Ellipse, Super Shape tools)
      Is There a Hotkey/ Command to Hide All Panels or Maximize the View?
      • gotanidea
      2183
      @gotanidea Will be in version 1.2
      How to Stick Two Rectangles using Alignment Tools?
      • gotanidea
      7886
      @gotanidea said in How to Stick Two Rectangles using Alignment Tools?: Could you please make it as simple as that? I will try.
    • Appearance Panel and Batch modifications
      • Ayo
      2186
      @Ayo It is in the backlog
    • Missing initial tangent line indicator
      • Ayo
      3865
      @VectorStyler said in Missing initial tangent line indicator: Is the first step a click (with release) or just a mouse press (without release) ? Press without release
    • When resetting stroke with stroke width adjustments, should it retain other attributes?
      6042
      @Subpath Got it.
    • Temporarily switch to the Transform Tool shortcut not global for drawing tools?
      • Ayo
      4092
      @Ayo If you want to move the rectangle (or any shape) mid drawing, press the Space bar and drag the object around. Works great with snapping.
    • How to control Hover Selection Outline
      • Ayo
      4474
      Nice! A lot is coming your way. Respect!
    • Can't find the node
      • Ayo
      10237
      @Ayo said in Can't find the node: The Collider Node I assume is the node appearing at the collision point between two shapes. In Indicator Shapes I can change the Collider Node all I want but it has no effect. Remains a Tiny Circle. This is now not in use anymore, as it is handled by a snapping indicator, will be removed. Which selection from Editing Options 1 should give the color and line settings for this node? This will be the "Collision Snapping Indicator"
      Clipping Group Content Nodes or Points in Outline Preview Mode
      • gotanidea
      2069
      @gotanidea No such option in VS for now, but it is easy to add. Will be fixed ASAP.
      Difficult to Select Object Behind Transparent Clipping Group
      • gotanidea
      2814
      I was testing out the double click options in preferences. I made the simple double click be "select inside" and it does not seem to work. If I double click on something visible that is inside another shape, it will not seem to do anything. I also made the option-double click also "select inside" and that works just fine. So it seems the double click by itself option is not functioning as it should in this setup. I will check some others and see how the perform
    • V
      How to Froce Device CMYK in EPS Export
      • VectorByName
      3532
      @VectorByName Added this to the backlog, and will get back with a solution soon.
    • Is there an easy way to determine the angle of an existing edge of a shape or path?
      2068
      @Boldline If it is a path, then select the node at the end of a line and the Path panel will show the angle.
