    • What modifier do I use with eyedropper to change the stroke of one object using the fill color of another?
      3005
      @Boldline I don't think there's a modifier for that. Press X to switch to Stroke color, then picking the color from the fill of the other object will assign it to the stroke.
    • How is the option for right-click submenu upon release of the control key best used?
      2638
      Baseline grid options
      • Kumr
      3022
      @VectorStyler Thanks. Will manage with that option.
    • Eraser brush seems to create shaking results and when zoomed in close, near straight lines
      4015
      @Boldline Path Editor Show Eraser Shape (and Path Brush and Knife),
    • vector with reduced opacity flashes between the lower and full opacity when editing nodes
      2783
      @Boldline Not supposed to be happening, looks like a bug.
      South Asian languages support
      • Kumr
      7322
      @Kumr Thanks for the update. After 1.2 beta is complete this will be one of the things to improve.
    • Should custom guides not be selectable unless clicked on directly?
      2782
      @Boldline Currently these are just regular objects. I open a bug on this one to have special handling for selection.
    • What are these folder options in the settings>folders>folder mode section?
      2714
      @Boldline In order of appearance: Preset Collections these are folders containing *.preset (VS) files, you can add these and presets will be scanned from there. Hyphenation custom hyphenation dictionary files. PPD File - Postscript Printer Definition files for VS Postscript printing (not with the host system driver).
    • Adding actions to the Actions Panel
      2374
      @Boldline The "Append" command should import actions into the panel, but it only works if there is at least an empty actions folder. I will fix this.
    • D
      Scale Strokes and Effects
      • danegeld
      59
      59
      134018
      @gotanidea said in Scale Strokes and Effects: The Transformed Stroke option in Transform panel menu, Object Options and Document Setup is not the same as Adobe Illustrator's Scale Strokes & Effects feature. Yes, these are different. I will try to implement a similar transforming mode. The problem is that it might conflict with existing features. I moved this feature up the the backlog.
    • Easy way to warp expanded text or shape to the confines of another shape?
      3373
      @Boldline Reverse the direction of the shape. And setting the first not (right click on shape node -> make first..) might also help.
    • Bucket fill tool does not seem to work correctly
      3589
      @Boldline Got it!
    • Last used preferences file not showing up in flyout menu
      3427
      @Boldline Oh… it's Preference files. I have only workspaces in my head. Sorry.
    • Knife tool issue or just user error?
      3391
      @Boldline also no problem here with the knife tool
    • Can shapebuilder to only fill the negative space?
      4494
      @Boldline Got the file, I will try to fix this ASAP.
    • Node's handle will only allow movement along a predetermined angle
      3494
      @Boldline Deleting a node between a line and a smooth node could result in this.
      How to delete color stops in gradient panel?
      6628
      @Harry Correcting what I said: I restarted to Sierra and AI CS5 has the trash can button there. I guess I always used drag to delete…
    • Adding anchor points / Make a path more complex
      • michaelokraj
      10978
      @VectorStyler Meaning this as a compliment, as VS can do everything from my experience: I am surprised we cannot do that until now ;). Also, I am thankful, you add this to the backlog
    • Where do I switch options for left-click and right-click controlling fill vs stroke/front or back square, etc ?
      3788
      @Boldline A Prefs setting that disables the current mode of assigning colors for the Color bar wouldn't hurt. (It could be that there is such a setting and I couldn't find it). What I'm not so sure of is having a setting that enables the same color assigning method for the Color Palette panel β€” it could be confusing because of the Fill/Stroke button combo in this panel. But I don't use both the Color Palette and the Color bar, so maybe I miss something here.
      Bloom effect – again a bug?
      • Buntstift
      8549
      @Buntstift Send me that file.
