    Expand Stroke Weird Result
    7 Posts 2 Posters 5.8k Views 2 Watching
    • G Online
      gotanidea
      Please open this file:
      0_1686798094436_Expand_Stroke_Test.vstyler
      If I apply Styles > Expand Stroke to the objects, the result looks weird. Is there another method to expand the stroke?
        VectorStyler @gotanidea
        @gotanidea Yes, replicated here also.
        G 1 Reply Last reply Reply Quote 1
        • G Online
          gotanidea @VectorStyler
          @VectorStyler Thanks for fixing Expand Stroke, but the result is not accurate (it becomes thinner) and it comes with a weird bounding mesh. Please see the screenshot below:
          Expand_Stroke_Result_is_Thinner
          If I ungroup it several times, it will disappear. So I have to apply Object > Convert to Curves to it and it will come with unnecessary objects, which I have to delete manually.
            @gotanidea When using Expand Stroke on a vector brush, it will convert it into a group with a bend effect on it.
            This allows the editing of the (expanded) brush content, while still retaining the original brush content distorted with a bend effect.
            Yes, a Convert to Curves is required to get to the actual distorted shapes, and this is by design.
            I will try to fix the thinning issue.
            • G Online
              @VectorStyler If we use Expand Stroke in Freehand or Outline Stroke in Illustrator, a vector brush stroke will be directly converted into a closed curve or path without additional bend effect.
              Getting the Bend Effect after expanding a vector brush stroke is good to have, but I think those Freehand's and Illustrator's workflows are also good to minimize the number of nodes in the scene and to reduce the artwork complexity/ file size.
              Could you please make another command called "Expand Stroke without Bend Effect" or maybe an option to exclude the Bend Effect when we click the Expand Stroke command?
                @gotanidea said in Expand Stroke Weird Result:
                I will find a solution for this. One could be to expand directly to curves (default Expand Stroke), and then a separate thing called Expand Brush for brushes only to get to the bend effect.
                G 1 Reply Last reply Reply Quote 2
                • G Online
                  @VectorStyler Thank you Admin
