      Snapping Gap vs Snapping Tolerance
      • pentool
      2462
      @pentool There might be a bug here, will be fixed ASAP.
    • How do I move an entire live text on a path (not move the text along the path)?
      2624
      Try moving the shape - and the text will move with it. Select the shape first (not the text). https://www.youtube.com/watch?v=6KmANbdIt7w
    • Copy Option/drag object constraign angle 45 degrees.
      • Ayo
      4260
      @VectorStyler said in Copy Option/drag object constraign angle 45 degrees.: @Ayo I will add the diagonal case. 1.1.095 Simple but feels much better now. Thanks
      Why does Shape Builder has a very tough time recognizing shapes?
      • pentool
      5623
      @VectorStyler Should the default value for 'Overlapping Gap' be kept at 0.1 px?
      Why I'm getting double grid snapping guide lines?
      • pentool
      7076
      Well, there are a LOT of grids. There are reference, parent and artboard canvases. They all can have grids (they have a little grid icon next to them in the Canvas & Artboard panel). Furthermore, all these canvases can have any number of artboards and they all can have grids. Phew... So even if you delete all the grids (in the Grid Editor) for all canvases and artboards except the artboard you are working on, you'll still have this issue. So not sure where the extra set of grids are hiding, if there are any.
      Xform rotation angle precision
      • pentool
      2230
      @pentool No option for this for now.
      Documentation: No "Limit" options for Grid Panel
      • pentool
      3385
      @pentool Yes, it was removed from the panel and only available in the modal view. I will update the documentation.
      FIX? Changing artboard position in modal view to move artboard guidelines also.
      • pentool
      2943
      @pentool After a bit more inspection, the bug was only half fixed. Additional fix will be in the next build.
      Cannot delete actions. Cannot create new action folder.
      • pentool
      10784
      @pentool I will try to replicate this. It might be a bug in how custom actions files are handled.
      presetname.adjustmentfilter
      • pentool
      2114
      @pentool It is a missing text resource name, will be fixed in the next build.
      Why am I getting these weird line working with the Anchor Point Tool?
      • pentool
      3065
      @pentool THat last line is the control point and handle of the curve to be continued by the pen tool. It should not be visible in the anchor point tool, I will fix this ASAP.
    • Marker for adding a node with node editing tool not always accurate to cursor position
      3317
      @Boldline Yes, this could happen with certain curves (control points aligned on the curve, or retracted to the ending). Send me that shape, and I will try to improve this.
      Why the "Place" tab in Artboard Options dialog is sometimes there and sometimes it isn't?
      • pentool
      2410
      @pentool The Place tab is not shown when the app edits options of multiple artboards. But I have to check why does it think that there are multiple artboards selected in this case, could be a bug.
      Licensing - how many computers?
      • pentool
      2572
      @pentool said in Licensing - how many computers?: I'm curious about how many computers can I activate a single license, say if I have a desktop and a laptop? You can use the same license on several of your computers. If the license is only for a single machine, what happens if I get a new one? Just use the same license on the new computer. Can I move the license over to the new computer without any issues? Yes. Does this require an unregistration of some sort from the older machine? No.
    • What does Keep Selection Mode setting do
      • Ayo
      3111
      @pentool thanks for the video didnt know this too
      Why vertical guideline grids are not showing?
      • pentool
      6917
      @pentool said in Why vertical guideline grids are not showing?: I think the reason you only saw still 2 guidelines on Artboard 2 because you moved it using the Artboard Editor Tool. Yes, that is the case. When changing the artboard position like that, the guidelines are not moved. I added this to the backlog as a bug.
      Why the artboard of "Artwork Canvas" cannot have a grid?
      • pentool
      2805
      Thanks, I was able to recreate it so it works fine. Not sure what I have done wrong initially.
    • No panels on startup, opening a backup copy does not work
      3804
      @encart said in No panels on startup, opening a backup copy does not work: Although you can see ticks in the panel menu, the panels are not visible I have the opposite - a lot of panels opened and a few panels ticked (since I work on VS - from version 1.1.06x):
    • Copy and paste line with a brush style
      • Ayo
      4821
      @Subpath said in Copy and paste line with a brush style: Sorry, I guess I'm missing the point. Don't get me wrong. Copy and paste line with a brush style does happen correctly when registered as preset in app. Not when not registered. Strange to me too. Anyway, registered in the buglog.
    • Can custom preferences file remain intact during updates?
      2335
      @Boldline said in Can custom preferences file remain intact during updates?: Is there a way to keep the same custom preferences file when performing a build update in VS? Normally, it should keep the current settings file. But there were some changes on how these are handled internally and it might have reset them.
