    Shape core-line setting?
    12 Posts 4 Posters 9.2k Views 3 Watching
    • AyoA Offline
      Ayo
      In VS, almost everything can be changed and adjusted in settings. That's nice but I can't find the following.
      Is there a setting that can change the black shape-core-line color and weight that pushes through everything? Seems like the preview line.
      VectorStylerV W 2 Replies Last reply Reply Quote 1
        VectorStyler @Ayo
        @Ayo The outline color of the selected shape is the Layer color in which the object is. The width cannot be changed.
        AyoA 1 Reply Last reply Reply Quote 0
        • AyoA Offline
          Ayo
          @b77 said in Shape core-line setting?:
          But you can change it in Preferences > Editing Options 1:
          choose 'Node Editing Outline' from Interaction Indicators;
          change 'Indicator Outline' from 'Layer' to 'Color' (and adjust the color) or to 'None'
          Thank you. But that affects only the Node Editing modus. Not the Selection modus.
          • AyoA Offline
            Ayo @VectorStyler
            @VectorStyler Pity!
            • b77B Offline
              b77 @Ayo
              @Ayo said in Shape core-line setting?:
              You're right. Deleted.
              • W Online
                William Kansepa @Ayo
                @Ayo, Have you tried to play around with the Transform Selection Frame setting and change the value of the thickness of the outline Indicator Outline?
                Or even change it to None?
                Or simply reduce the opacity from 100% to 0%?
                Refer to attached image.
                • b77B Offline
                  b77 @William Kansepa
                  @William-Kansepa Good to know, but that one changes the color of the bounding box.
                  If I understand correctly, Ayo wants to change the shape-based contour.
                  W 1 Reply Last reply Reply Quote 0
                  • AyoA Offline
                    Ayo
                    Indeed. You beat me. Thanks
                    Answer and options are provided by ADMIN earlier.
                    • W Online
                      William Kansepa @b77
                      @b77 , like you previously pointed out, the Node Editing Outline setting will change the shape-based contour. But if you look at the picture which he had attached we do see a bounding box and the line that he mentions.
                      • b77B Offline
                        @William-Kansepa The screenshot posted by Ayo shows the shape in
                        selection mode, not in node editing mode.
                        Ayo wants to customize the shape-based line when in selection mode.
                        That's why my first reply didn't help.
                        But what matters is that you and me dug into these settings, and we know VS better as a result. 🙂
                        @VectorStyler It looks like if I select 'None' for 'Node Editing Outline', there is
                        still a thin black line displayed over the shape.
                        • AyoA Offline
                          Ayo
                          Exactly I'd like to know that too, but I'll post it in a new topic.
                          • b77B Offline
                            b77 @Ayo
                            @Ayo I'm back to this discussion:
                            Are you requesting a way to change the shape's "core-line" when selected because editing the
                            color of the stroke is more difficult when this colored contour is superimposed over the shape?
