    • Adding object attributes annoyance
      6092
      @Igull Also: clicking on the button that opened a popover should close the popover. The problem with using the Esc key is that after selecting the color (first click), the key input assigned back to the document and Esc is used as a shortcut or to close the isolation mode.
    • Scale VS workspace to fit fully on screen
      3091
      @Boldline Did you try a two-column toolbox? (Panels > Toolbox Style > Two Column)
    • Unable to add a new color to an existing color palette
      8284
      @Boldline OK, good to know. Well, dragging a color to the Color Palette Bar to add it there would be nice, I agree.
      Image effect: on individual or grouped objects
      4883
      @VectorStyler ok great, good to know
    • Set VS to paste vectors on selected layer and not top layer by default
      3223
      @VectorStyler ok it's working on a fresh reboot of VS. The vectors imported had been from another VS file. I initially thought it was a setting to swap, like a "always paste to top layer" and not a bug or restart issue - hence why I had posted the question. All set for now
    • Distribute objects with value?
      10401
      @Igull is even possible to do some Math here
      Blending & alignment of objects
      2701
      @VectorStyler Nice to know, looking forward to v1.2
      Layer panel: to select several objects
      2337
      @Pat Swiping through multiple round knobs will select those. I added the Shift+ thing to the backlog, maybe it should select between.
    • Sometimes double-tapping the "L" key to convert a node to cusp gives me the path sketch tool instead
      4504
      @VectorStyler said in Sometimes double-tapping the "L" key to convert a node to cusp gives me the path sketch tool instead: Looks like that if the command fails (already cusp), it falls back to default. Yes! You put that so succinctly! That would be great fix. Thanks
      Does SVG Not Support Opacity Mask?
      • gotanidea
      5247
      @gotanidea There are other issues also. Transformation of groups that contain masks are not transforming the masks correctly. I will try to fix these for the next build.
    • Repeater takes massive amount of resources to do small commands
      7035
      @Subpath said in Repeater takes massive amount of resources to do small commands: The steps that are necessary for this are explained in this tutorial section here, in case you dont remember: I appreciate you sharing all of that again. I will certainly check it out and see what else can be done!
      Paragraph panel
      7780
      @VectorStyler Thanks. I've tested on my two W11 pc & it is the same issue.
    • Shape core-line setting?
      • Ayo
      7946
      @Ayo I'm back to this discussion: Are you requesting a way to change the shape's "core-line" when selected because editing the color of the stroke is more difficult when this colored contour is superimposed over the shape?
    • R
      Crash due to system UI font call.
      • richbyte
      4658
      @richbyte You can use the Console app (from Applications > Utilities) to find the last crash report for VS.
      Expand Stroke Weird Result
      • gotanidea
      4936
      @VectorStyler Thank you Admin
    • Modal Dialogs on Mac
      4996
      The whole "Delete" thing came into play around the same time that Apple started pushing "auto-save": with auto-save, the document is saved automatically and continuously, so there is no concept like "Don't Save" any more at that point. "Delete" makes more sense once you have an auto-saved document and want to get rid of it, but if it was never saved in the first place, then it becomes confusing, and if it was, then it should save automatically anyway, so there is no reason to prompt... the way the whole "auto-save" thing is presented to users was poorly designed in my opinion, particularly as it is mixed in with apps that will and will not use it adding further to the behavioral confusion.
    • What is different about adding a spot color via the artboard tool compared to manually using the plus sign icon in the palette panel?
      6777
      @b77 said in What is different about adding a spot color via the artboard tool compared to manually using the plus sign icon in the palette panel?: Expanded to RGB or CMYK color mode, depending on the document color mode? Expanded to the color mode of the original spot color.
    • How do I view the 'Shape Editing Indicator'?
      • Ayo
      5202
      @VectorStyler These two at least could display the tool name in parentheses, like this: Shape Erasing Style (Trim and Join tool) Shape Editing Indicator (Grid, Super Ellipse, Super Shape tools) Btw, the last one is a slider, so a better description could be: Shape Editing Slider (Grid, Super Ellipse, Super Shape tools)
      Is There a Hotkey/ Command to Hide All Panels or Maximize the View?
      • gotanidea
      2477
      @gotanidea Will be in version 1.2
      How to Stick Two Rectangles using Alignment Tools?
      • gotanidea
      9390
      @gotanidea said in How to Stick Two Rectangles using Alignment Tools?: Could you please make it as simple as that? I will try.
