      Can shapebuilder to only fill the negative space?
      @Boldline Got the file, I will try to fix this ASAP.
      Node's handle will only allow movement along a predetermined angle
      @Boldline Deleting a node between a line and a smooth node could result in this.
      How to delete color stops in gradient panel?
      @Harry Correcting what I said: I restarted to Sierra and AI CS5 has the trash can button there. I guess I always used drag to delete…
    • michaelokrajM
      Adding anchor points / Make a path more complex
      michaelokrajM
      @VectorStyler Meaning this as a compliment, as VS can do everything from my experience: I am surprised we cannot do that until now ;). Also, I am thankful, you add this to the backlog
      Where do I switch options for left-click and right-click controlling fill vs stroke/front or back square, etc ?
      @Boldline A Prefs setting that disables the current mode of assigning colors for the Color bar wouldn't hurt. (It could be that there is such a setting and I couldn't find it). What I'm not so sure of is having a setting that enables the same color assigning method for the Color Palette panel β€” it could be confusing because of the Fill/Stroke button combo in this panel. But I don't use both the Color Palette and the Color bar, so maybe I miss something here.
      Bloom effect – again a bug?
      @Buntstift Send me that file.
    • IgullI
      Context Panel Position
      @b77 Thanks for that, I'll give that a try this morning - he only needs a few tools for "simple" drawings, so trying not to overload with everythingthat comes in the trial download Neil
      blend - Color Rainbow
      @STEVED said in blend - Color Rainbow: Can someone tell me where I can access this Hue angle thingie. In the Color panel menu, select HSB Sliders, then the Hue will be the first component.
      What does the "c" stand for in the descriptor in the upper left corner of VS?
      @Boldline said in What does the "c" stand for in the descriptor in the upper left corner of VS?: Merge does not do this I added this to the backlog.
    • _
      Layer panel scrolls too fast ...
      @_NM_ I reopen this issue. I did change the scrolling speed, but it seems that it is still too fast.
    • _
      Question about duplicating objects
      For anyone who is reading this: Preferences/Settings > Adjustments > Duplicate Offset.
      New computer: Vectorstyler does not accept license key.
      22
      31k Views
      @Gremriel I added this to the backlog and will try to replicate it.
      It is not clear how to use Reference Canvases
      @pentool Added this to the backlog and will try to replicate.
      Why edit corner point is off?
      Thanks, yeah, I did not convert it to curves, maybe that was the issue.
      No editing handle visible for spiral gradients
      @pentool The spiral gradient shape cannot be edited as a shape, you need the concentric or axial modes for that.
      DOCUMENTATION: Gradient Panel menu > Flip Colors
      @pentool Will be fixed.
      Background color assigned to the artboard not register as a color when printing?
      @Boldline The print preview is wrong in this case.
    • _
      Section 3.9 Path Panel in the manual: Where is the Path Panel?
      @_NM_ This is a bug in VectorStyler that I could not replicate it yet here. Somehow the old resources (text in this case) end up in the user folder (probably) and the new version after updating ends up using the old resources.
      Create your own palette
      The idea here is that if you get a brand guide from a client specifying, say, 5 colors, you want to create a palette that contains only these colors. I don't need 128 other "default" colors. Just the brand colors for this specific project. There doesn't seem to be an easy way to accomplish this.
      Clicking Existing live text box does not allow for easy editing
      @Boldline What font was used in that text?
