    • Appearance Panel and Batch modifications
      • Ayo
      2539
      @Ayo It is in the backlog
    • Missing initial tangent line indicator
      • Ayo
      4466
      @VectorStyler said in Missing initial tangent line indicator: Is the first step a click (with release) or just a mouse press (without release) ? Press without release
    • When resetting stroke with stroke width adjustments, should it retain other attributes?
      7004
      @Subpath Got it.
    • Temporarily switch to the Transform Tool shortcut not global for drawing tools?
      • Ayo
      4647
      @Ayo If you want to move the rectangle (or any shape) mid drawing, press the Space bar and drag the object around. Works great with snapping.
    • How to control Hover Selection Outline
      • Ayo
      5345
      Nice! A lot is coming your way. Respect!
    • Can't find the node
      • Ayo
      12047
      @Ayo said in Can't find the node: The Collider Node I assume is the node appearing at the collision point between two shapes. In Indicator Shapes I can change the Collider Node all I want but it has no effect. Remains a Tiny Circle. This is now not in use anymore, as it is handled by a snapping indicator, will be removed. Which selection from Editing Options 1 should give the color and line settings for this node? This will be the "Collision Snapping Indicator"
      Clipping Group Content Nodes or Points in Outline Preview Mode
      • gotanidea
      2338
      @gotanidea No such option in VS for now, but it is easy to add. Will be fixed ASAP.
      Difficult to Select Object Behind Transparent Clipping Group
      • gotanidea
      3340
      I was testing out the double click options in preferences. I made the simple double click be "select inside" and it does not seem to work. If I double click on something visible that is inside another shape, it will not seem to do anything. I also made the option-double click also "select inside" and that works just fine. So it seems the double click by itself option is not functioning as it should in this setup. I will check some others and see how the perform
    • V
      How to Froce Device CMYK in EPS Export
      • VectorByName
      4132
      @VectorByName Added this to the backlog, and will get back with a solution soon.
    • Is there an easy way to determine the angle of an existing edge of a shape or path?
      2382
      @Boldline If it is a path, then select the node at the end of a line and the Path panel will show the angle.
    • Text Horrors
      7693
      @Igull It would help some to take screenshots and do some screen recording and including those with your questions so others can see what you are dealing with
    • Select from within overall selection?
      2851
      @Boldline You can isolate some of the objects by hiding the others, then Select by Style works only on those that are visible: select some objects on multiple layers; invert the selection; hide these (Object menu > Hidden); select an object with the attributes you need (say, pink rectangle) and… use Select > Select by Style > Fill Content.
      Are there any plans to create a searchable PDF of the Documentation?
      • kevphil
      2925
      Hi @kevphil There is a searchable pdf linked in the tutorials section of the chat forum. Here is the direct link to it.
    • 3D Help
      27
      27
      30026
      @fde101 said in 3D Help: @Igull not sure about the demo version, but I have a paid license of Art Text 4, and I can just drag a PDF exported from VS into the Art Text window and it loads it as a 2D shape. I can then right-click and convert to 3D after which an option to set the extrusion depth becomes available in the properties area on the right. Mmm, tried a number of PDFs all of which dragged across, but didn't show on the artboard (or only showed the bounding box - and you couldn't right click to create 3d)- seems extremely slow and very unstable (tried it on an M2 this afternoon - a bit faster, but same results) - may be something to do with the demo version. But all it has is a TRIAL watermark, everything else is supposed to work according to the info. It's probably fine for doing text and minimal 3D objects I think - might be too much heavy lifting to move all my bits around. Thanks for the info, I'll keep the trial, might find other uses for it ! Neil
    • New from Clipboard Fail ?
      4868
      @Igull yes, your right its somewhere below the artboard
    • V
      Spot Colours Not Retained After Saving and Reopening VS File or Exporting EPS File
      • VectorByName
      4407
      Many thanks, hopefully, a relatively easy fix...
    • V
      LAB Colour Support in VS Exported .ASE Files
      • VectorByName
      2594
      @VectorStyler said in LAB Colour Support in VS Exported .ASE Files: This sounds like a bug, added it to the backlog. Many thanks and thanks for confirming...
      Artboard Guideline not shifting position
      • William Kansepa
      2929
      @VectorStyler Thank you
    • V
      Colour Palette Sliders are Missing
      • VectorByName
      4621
      Perfect, no idea how I completely missed that despite looking for it several times (must be menu blindness), many thanks...
    • Has the "node removal curvature" been altered some?
      3557
      @VectorStyler I reinstalled a couple older builds (73 and 80) and tested the same file in both and I'm getting similar results to build 85. Perhaps it's just something I'm imagining. Or perhaps it has to do with the kind of art I am working with. I appreciate you checking regardless. thanks!
