    • Preferences > Adjustments > Tracking change begins from 10%
      3253
      @encart Fixed in build 1.0.048
    • C
      Drag-scaling text element does not change displayed point size
      • cjochetz
      16616
      @Gremriel This should be fixed in build 1.0.048.
    • [Path drawing] Problem with closing a path . Endpoints do not merge into one.
      4547
      @encart The end point should now snap to the starting point if close in build 1.0.048
    • VS loses paste function when attempting to paste vector from Illustrator CS2
      4535
      @Boldline The exported (for clipboard) PDF version is now set to 1.6 (was 1.7 before). This should work with CS2. Let me know if there are still issues.
    • imported images have two strange lines in them
      imported images • • Boldline
      6868
      @Boldline Pasting images from the clipboard had some (replicated) issues. These have been fixed in the new build 1.0.048
    • Merge Boolean not always Working
      5552
      @Boldline There were improvements to Merge boolean in the new build (1.0.048). I will close this topic and lets open an other one if new issues are encountered.
    • V
      Offset Path and Offset Path "Effects" Scrolling not Working in some Entry Fields; Boundary Offset Issues
      • Vector-Rock
      3997
      @Vector-Rock There have been improvements to the Offset Path, and the other reported issues in the original post (build 1.0.048).
    • V
      Offset Path Inaccuracies. Gap in Stroked Offset.
      • Vector-Rock
      4885
      @Vector-Rock There has been improvements in the Offset Path. I will close this now, and lets open a new topic with new issues when found.
      Flickering canvas on M1
      • Kyriakos
      16155
      @Kyriakos @encart Can the flickering issue be replicated? There is a double buffering enabled for all display types now.
    • Copying and pasting from one layer to another does not copy all of selection
      6767
      @Boldline There has been fixes to the pasteboard recently. I cannot replicate this issue in build 1.0.048, and I will close it for now. if there are further pasteboard issues, we can open a new topic.
      Bug? Swatches stay highlighted without an assignment or object selection
      • Arde
      4392
      @Arde This should work in as requested in the latest version.
    • V
      Artifacts created in Offset Path, Offset Path Effect...with larger values
      • Vector-Rock
      3104
      @Vector-Rock The Offset Path has been improved in recent builds (1.0.048), I will close this issue and open a new one as new issues are discovered.
      Wrong font shown for selected vector shape texts
      • Arde
      5578
      @Arde This issue should be fixed in build 1.0.048
      Outer stroke seems to be broken
      • grix
      5540
      @vectoradmin Stroke alignment (and offset path) has been improved in the new build 1.0.048. I will close this issue, and open one when new issues are found.
    • Ability to change color and stroke when creating an Offset Path
      7551
      @vectoradmin I followed all your directions. Unfortunately, no changes.
      Selecting color can only be done in steps, unless the color selector palette is undocked (Windows)
      • Gremriel
      4895
      Hi, Ok, I understand. It seems that by lowering the drag speed allows me to select a color that is closer to where the 'dot' was when I clicked on it.
    • Failure to switch from the Text tool (T) to other tools
      4055
      @vectoradmin Thanks. I have confirmed that it is fixed. Comfortable to work with.
    • Typing a Comma while within a text box brings up split view
      3691
      @Boldline Fixed in build 1.0.046
    • Are there two Style buttons in the text context menu bar?
      3551
      Issues with effects applied
      • gentlecl
      7947
      @gentlecl Fixed in build 1.0.046
