Ability to change color and stroke when creating an Offset Path
Can you add a color & stroke change when creating an offset. Currently, when the Offset Path popup window appears, this is not possible. If the Stroke parameter is set to zero, the created offset is invisible until the window is closed and the color is changed.
@encart Added this to the backlog as a new feature.
@encart This has been fixed in build 1.0.044
https://recordit.co/SIYIKNrObi
When I run the program and want to use the Stroke coloring in the Offset Panel for the first time, it doesn't work. I have to accept without preview and it appears in the project. Only after this process is the Stroke preview visible. For the next use, it remembers the last color selected. No change possible
@encart The stroke width must also be selected. In the video it shows Hairline.
@vectoradmin Changing the stroke width is also impossible
@encart Tried both on Windows and Mac and I cannot replicate this issue. Both the Color and the Width can be changed and they are previewed as expected. (I also added the Offset Path command to the toolbox to make everything the same as in the video).
One thing to try would be to reset the workspace, but the customized toolbox may be lost with that.
The toolbox can be saved into separate file in the Customize Toolboxes view, and then reloaded if the workspace is reset.
@vectoradmin I followed all your directions. Unfortunately, no changes.
