    • Lag in Huion tablet while Windows Ink is turn on. Blue spot moves slower than the cursor shape
      6294
      @vectoradminit Looks like all lag has been eliminated. Thanks!
      (Win beta 1.0.021) Copy Paste Issues
      shortcut keys zoom copy and paste ui improvement too many groups • • WhiteX
      17248
      @vectoradmin This is great. The default settings are working fine! Thanks a lot!
    • The symbols used in the canvas are also edited in the Presets panel
      5905
      @encart This has been fixed in build 1.0.044
    • V
      Nudge Moving Distance Issues
      • Vector-Rock
      4511
      @Vector-Rock This has been fixed in build 1.0.044
    • Spelling error
      3691
      @Boldline This has been fixed in build 1.0.044
    • Microsoft Print to PDF crashes the app.
      6615
    • Errors when highlighting text
      4928
    • [Toolbox]Custom shortcuts may change active tool in tool-groups when they are duplicated.
      4581
    • Spelling error in Actions Menu
      4608
    • V
      Contour Panel- Cannot Adjust Width or Precision Values Incrementally with Arrow Keys
      • Vector-Rock
      3671
    • Changing values by scrolling in fields with % unit changes by 120% per step
      3922
    • V
      Navigator Panel Object Rendering Problem, Red Navigator Artboard with Keyboard Scrolling Arrows
      • Vector-Rock
      11132
    • Closed offset Path and brush stretching make stroke Disappear
      3812
      @vectoradmin This has been fixed in build 1.0.044
      Pen, Brush and Text tool fill colours resetting to transparent or black
      • Kyriakos
      8191
      @Kyriakos Sorry for the late reply, but this issue should be fixed now.
      Cannot specify layer color (RC19, Windows)
      • Arde
      5872
      @Arde I cannot replicate this issue with the latest Windows build. Is this still a problem?
      VS is completely broken on my system (Mac OS High Sierra)
      • postdes
      6569
      @postdes Replicated! Turning off the rulers is the issue.
    • V
      Items Left Behind in Layers Panel when Artboard is Empty
      • Vector-Rock
      4591
      @Vector-Rock This one can be replicated easily now, and will be fixed. The composite shape was empty because the result from combining the 3 shapes was an empty shape due to a bug. The bug will be fixed in the next build. BTW: in this case one of the shapes is not necessary, as it is the boundary of the other two, and the composite shape is also creating a boundary (kind of creating boundary twice). About the forum images: yes there is some size limit to the images. I will check if this can be increased, but there will be some limit anyway to keep space under control
    • V
      Adjustments to the Guidelines Panel Column Widths not Retained After Closing
      • Vector-Rock
      3333
      @Vector-Rock Added to the backlog, will be fixed in the next build.
    • Imported SVG's are invisible until ungroup & position of imported files
      4997
      @encart Got this replicated. It is just a missing refresh issue after importing. Press Control+R on Windows to refresh after the file is imported. Added to the back, will be fixed in the next build.
      Printer marks do not work correctly
      • Arde
      25
      25
      48589
      @vectoradmin īŧˆ1.0.041īŧ‰ The basic functions seem to have been fixed. As I mentioned in the previous post, it is better to fix the line widths of marks. Improvement: Each of the following should be set to 0.09mm. -Crop:0.18mm <- too thick -Bleed:0.18mm <- too thick -Resistration:0.02mm <- too thin In actual printing, various data are pasted on the outside of the Artboard as needed depending on the process. However, I think this is sufficient for small office.
