      Upper-right buttons not working.
      • abn5x
      5677
      This is fixed in build 146
      Round Corners Distorted BUG
      • abn5x
      9412
      Round Corners Limit BUG
      • abn5x
      6853
      App Crash while in Offset Path dialogue.
      • abn5x
      5917
      Dashed Line Align to Cusp Artefact
      • abn5x
      7281
      This has been improved in build 146
      Stroke panel ALWAYS above every Window
      • abn5x
      5661
      High CPU usage for COG Shape
      • abn5x
      6804
      All requests are welcome They will be prioritized of course, bugs first, then features. Performance is critical, but getting to AD level might not be feasible in the short run. Maybe small improvements.
      Unable to open svg on Mac desktop
      • Buzzer
      6900
      Fixed in build 144.
      Perpetually highlighted Selection Tool button
      • Buzzer
      4791
      Hi. Thanks for the feedback. This is intended functionality: The "box" selection tool is active at the same time as other tools are active. The selection modes are box, magic wand, lasso and polygon tools. The selection tool is "active" in combination with an other tool. For example: lasso selection can be used with the node tool.
    • Negative Stroke
      • badcat
      5020
      This will be fixed in the next build.
    • D
      Text differences between VS file and PDF exported from VS
      • dla001
      6207
      will look into this
    • D
      PDF import not working properly
      • dla001
      7079
      Problem fixed in build 111, available for download.
    • D
      Open PDF from Excel doesn't work properly
      • dla001
      17443
      Text positioning of PDF import is improved. When fonts are replaced in PDF import spacing may be different (due to font metrics). In some cases keeping the original (PDF) character positions is desirable (if the new font is close to the original). In other cases it may be better to format the text using the new font. This can be controlled with the Preferences -> Storage -> Import Text Position checkbox.
    • D
      Open PDF with pdf imprints shows all imprints as single line of text, no longer in place
      • dla001
      7926
      The latest release fixes this problem.
    • D
      Can't see entirety of Main Toolbox
      • dla001
      9733
      Thanks! fixed it.
    • D
      Open (or drag and drop) PDF shows no objects
      • dla001
      5548
      This is fixed in the new release (beta 93).
      Color panel
      • louis1
      5041
      This has been added to the latest release
    • Wacom tablets
      • VectorStyler
      5443
      @vectoradmin fix has been provided to work with older Wacom tablets as well
      The ability to "cut" an object
      • maljones
      8202
      Now I see that was the Knife tool. You need a Scissor tool. You also need to use the "Break Apart" command with the commands from the Path panel to separate a shape cut in parts, into multiple objects. I'll think about a Scissor tool, if it is not difficult it could be done.
      Shift + Left Arrow moves items at a too small interval
      • maljones
      6487
      Confirmed! This bug is fixed.
