    • Transform: Up-dwn-keys act strange on stepping values i value fields
      4632
    • Documentation: Image in Chapter "Panel Menu" needs update
      4196
      @Raaskot Thanks for noticing, I will update this.
    • Transform Bugs ?
      15083
      @VectorStyler Yes, definitely fixed and works as expected now (for me at least ) Something else that is fixed it seems is the object refresh after changing it's size via the transform panel - prior to 080, the new object size indicated in the panel correctly, but was changed on screen. I'll keep my eye on that just in case I might be wrong Thanks Neil
    • Scaling issue happens in Windows, too
      7751
      Hello there! I noticed that this forum post is quite old, but I'm here to help nonetheless. If you're still experiencing issues with scaling on Windows 10 and VS 1.1, I suggest checking out some online forums or tutorials to see if anyone else has had similar issues and found a solution. Regarding the crash log, have you tried searching online for its location on Windows 10? That might help you locate it. Additionally, if you're still looking for a cheap windows 10 key, you might be able to find one online for a reasonable price. It's interesting to hear that scaling issues aren't just limited to Macs. Technology can be tricky sometimes, but don't worry, there's usually a solution out there somewhere. Keep us updated on any progress you make!
      Full screen mode doesn't fit to screen.
      25408
      @Jayanta-Das Added this to the backlog.
      Lock-aspect-ratio does not stay locked
      • A Former User
      12975
      @b77 Ok, this could be a new feature. Added it to the backlog.
      Transform/rotate after blending, weird behaviour or crashes VS
      23249
      @VectorStyler You can test on all the files I sent you including the one from last week. Just use the Object-Transform-Transform/Rotate feature(s) with 'clone' and you will finally get the issues. Just compare with 'Copy' where all the object changes are done correctly. Thanks.
    • C
      File crashes when opening
      • coolio00111
      32
      32
      65866
      @coolio00111 said in File crashes when opening: Also was having some issues where I would click a text box, be able to edit the text, then if I click the text box again, the text wouldn't be able to be edited. I would have to re-open vectorstyler. If you find what causes this, don't forget to report it to the developer.
      Where is the Crash Log File in Windows Explorer? App Always Crashes & Asks About Missing Links
      • gotanidea
      6696
      @VectorStyler I can't find that path on my system, but I finally find the crash log files in C:\ProgramData\NumericPath\Crash Logs
      Gradient Mask Effect fails to transform
      • William Kansepa
      6415
      Thank you @Vectorstyler. It worked, but I would prefer that Transform Mask Content be enabled by default. I think it would be more efficient that way. I feel it's an awful bore to have to revert to the Transparency Panel Menu each time I need to make a transformation. All the same I also would like to tap into other users input. I very much would want to hear their thoughts on this one.
      Error in reading Illustrator layer hierarchy
      • Arde
      5773
      @Arde In Preferences enable Document Files -> Import AI data from PDF. this option is disabled by default for PDF files so that the actual PDF content is imported. and by default, AI content is only imported from files with AI extensions. same happens with EPS.
      This topic is deleted!
      • Gremriel
      (072) Composite Mode - cant select a cutting Shape
      7995
      @VectorStyler Thanks for the info But I am not very familiar with AI. Have always avoided it, didn't like the user interface. Coming from Coreldraw, Xara Graphics Designer but i know more or less many other vector graphic programs and vector graphic tools
      pen tablet double click
      10324
      @Jayanta-Das said in pen tablet double click: There is still some issue with pen tablet. Like in Brush panel, Color panel Same here with Xp pen Deco V2 tablet Icon's descriptions doesn't pop up also - with mouse is ok.
    • Merging expanded text causes some to disappear and the rest to strokes no fill
      6404
      @Boldline Tried to replicate as it was in the recording, but here Merge worked.
    • C
      Move center point when scaling points
      • Clausj
      8867
      C
      @VectorStyler Good job! Seems to work as expected. Thanks!
      When Using Text Tool, Cannot Switch to Pan View Tool by Pressing Spacebar
      • gotanidea
      15851
      @VectorStyler Thank you
    • [0.72] Regression. Text is not scaled proportionally without modifier key
      5806
      @VectorStyler Yes, that was the reason. I should check this first. Thank you.
    • Moving tangents deselects the node options
      6595
      Fixed in 72
    • Transparency via keyboard does not work (Windows .057)
      14673
      @VectorStyler said in Transparency via keyboard does not work (Windows .057): @VectorStyler This issue should be fixed in build 1.1.072 Yes, VS responds correctly to keyboard input now (tested on Windows 10 laptop) but the parser does not allow 0% - not even when 000 is entered.
