      Copy /paste issues ..win 10
      • gentlecl
      9001
      @gentlecl Windows copy paste issues were fixed in build 1.0.046
    • [Pen Tool] [Win10] [1.0.045] First segment not showing preview
      • syllie
      3927
      @syllie Fixed in build 1.0.046
    • [Win 10[[1.0.045] Stroke width set to pt, reported in mm
      • syllie
      3522
      Clipped text in Appearance panel (Mac, v1.0.045)
      • Jono
      3388
      @Jono Fixed in build 1.0.046
      Swapping line and fill style (Mac, v1.0.045)
      • Jono
      3462
      Blend modes for layers are buggy
      • postdes
      7082
      @postdes Fixed in build 1.0.046
    • Typo when hovering over path eraser toggle
      2936
      @Boldline Found it, will be fixed in the next build.
    • Offset Path not all options are previewing
      2663
      @Boldline Yes, this can be replicated. Added to the backlog as a bug.
    • Stroke Width Panel's Stroke Profile image not keeping up with new selection
      2841
      @Boldline Could not replicate this one. What was the selection?
    • Paning is locked when Simplify Path popup window is active.
      7652
      @Boldline I add the ghost image idea to the backlog.
      Online fonts not listed in Windows version
      • Arde
      12028
      @Arde Type 1 font exporting into PDF format should work in build 1.0.045
    • V
      Color Panel word “Opacity” has the left Edge of the “O” clipped Off
      • Vector-Rock
      4851
      @Vector-Rock Should be fixed in build 1.0.045
    • V
      Click Near Edges the Artboard causes Scrolling
      • Vector-Rock
      4371
      @Vector-Rock This is fixed in build 1.0.045
    • Collapsing open panels and moving them around causes VS to shut down
      4472
      @Boldline This problem (was replicated) is fixed in build 1.0.045
    • Can not jump the cursor between text fields
      3900
      @encart This has been fixed in build 1.0.045
      Accidentally going into isolation mode
      • postdes
      7486
      @postdes @Boldline Added an option (Preferences -> Document Editing -> Double Click with Tablet) to disable double click in the document editor when using tablets (mouse will still double click).
      Updating Vectorstyler through the program doesn't work...
      • Buzzer
      6413
      Just tried to update to 1.0.044 and it worked flawlessly. No need to Shift-Option-Command.
    • C
      Collider Tool only allows snapping to inside of shapes
      • cjochetz
      5045
      C
      Duh, thanks. I misinterpreted your instruction. ‍️
      Locked a guideline in one document, now I can't drag guidelines anymore (Windows, 1.0.044)
      • Gremriel
      3621
      Thanks. It seems I still need to get used to a lot of things inheriting settings!
    • C
      Some panels missing icons
      • cjochetz
      4420
      C
      Confirmed that the update this morning fixes this issue.
