      Mirroring / Flip does not work as expected
      8788
      @vectoradmin Hi Just like to say, that with the latest Update 1.0.057 everthing works fine now.
    • Line Shape Grid issues
      5844
      @vectoradmin Hmmm I does seem a little redundant that the controls in the line shape grid and other shapes available on the vertical toolbar are basically offered as well in the shape panel. Now that I understand how it functions, I'm not as bothered by the preview and controls available in the line shape grid and other shapes panels available by double clicking in the vertical toolbar Maybe worth just leaving alone for now?
      Update not installing (Mac)
      • LordGytrash
      5942
      @vectoradmin - thanks, manual installation has worked fine!
    • C
      Font not rendering
      • Clausj
      5942
      C
      In the meantime I converted some of my old fonts with the app TransType 4. I recommend if anybody else has this problem and find it difficult to get updated original fonts.
    • do not open layer when duplicating in layers panel.
      4475
      @Boldline The duplication (with buttons) should keep the layer / group closed in build 1.0.055
    • Split text feature does not work.
      11722
      @encart @Boldline @b77 The split text issues are fixed in build 1.0.055
    • [Clipping Group] Issues with Intersect/Expand ; An Object inside the group changes position when main shape is conveted to curves.
      3876
      @encart These issues are fixed in build 1.0.055
    • App crashing whenever I want to activate a custom toolbox
      7191
      @encart @Boldline Toolbox customization has been improved in build 1.0.055
      Some panels are not responsive
      • KF
      4077
      @KF There are some fixes regarding panel management regressions, in build 1.0.055
    • [Pencil Tool - rope stabilizer] The line does not end at the end of the rope depending on the zoom
      3419
      @encart This should be fixed in build 1.0.055
    • [Application Shortcuts ] Label for Undo shortcut changes depending on the last operation.
      3806
    • Redo Button is grayed out / inactive.
      4587
    • White Squares instead of Glyphs popup previews
      3207
      Not seeing line attributes
      • Jono
      5145
      @Jono The guide rendering bug should be fixed in build 1.0.055
    • panels regression
      11958
      @Boldline This regression is fixed in build 1.0.055
      Eraser function for Pencil tool broken
      • postdes
      4803
      @postdes This regression should be fixed in build 1.0.055
    • [Transform Panel] Width units changing from mm to meters
      3497
      @encart At the first click, the whole field should be highlighted, and typing should erase all. Is this working? The problem with partial deletion is that it should be possible and allowed, and that includes ending up from mm to m.
      Screen not rendering consistently for some zoom levels
      • Jono
      8885
      Same here, every thing seems fine, since Version 1.0.054
    • Crash Report Misspelling
      2528
      @Boldline Will be fixed.
    • [Path drawing] The first point's handles position change toward the second .
      4620
      Thank you. It's fixed.
