      Lines: spacing... functional ?
      10412
      @Pat This issue should be fixed in build 1.1.072
    • Oval Shape panel not resetting?
      4691
      @Boldline This issue should be fixed in build 1.1.072
      Activation of Boolean operations
      • Wurstkäs
      10118
      @Wurstkäs This issue should be fixed in build 1.1.072
      Grouped clone disappears after double clicking
      3863
      @Harry This issue should be fixed in build 1.1.072
    • Prefs - Performance - Hovering selection
      4041
      @Ingolf This issue should be fixed in build 1.1.072
      Shapebuilder tool still big problems with UNDO
      • MajorTom
      4410
      @MajorTom This issue should be fixed in build 1.1.072
      Effect-->Replace colour--> Colorize : bug ?
      3658
    • R
      Panel graphic popup menus displaced if on second monitor
      • Raven
      5309
      @Raven This issue should be fixed in build 1.1.072
      Pen tool
      5971
      @Jayanta-Das This issue should be fixed in build 1.1.072
    • Rectangle panel hover info not correct
      3367
      "Cotton buds" line style with stylus - after upgrading to build 1.1.067
      8410
    • Text Drag Option Not working in Build 67
      4819
      Clipping Group regression
      • William Kansepa
      3843
      @William-Kansepa This issue should be fixed in build 1.1.072
    • Brush color switches to white when change is made to brush size with bracket keys
      4241
    • When changing the shortcut key, the letter keys allow you to enter text
      4270
      @encart This issue should be fixed in build 1.1.072
      Undo after applying a colour gradient
      4187
      Smooth node mode bug?
      • William Kansepa
      4827
    • If transform selection box is not set at 90 degrees, it creates a wonky offset path
      5182
      Pattern Brush from Blends seems to be broken
      4140
      @Subpath This issue should be fixed in build 1.1.072
    • Text on a path seems to have issues when you flip to opposite side
      5680
