    Move center point when scaling points
    5 Posts 2 Posters 9.6k Views 2 Watching
    • C Offline
      Clausj
      I want to select several points of a curve and scale them with a certain origin. However during this operation I'm unable to move the center point (origin of scaling operation). Is this a bug? The manual states:
      Hover over the center node indicator. The cursor should change to indicate center node selection. Press and drag the mouse.
      Move the center node to a new location.
        VectorStyler @Clausj
        @Clausj Center adjustment works for objects only at this time.
        I open a bug on this one, and will try to implement for nodes also.
        C 1 Reply Last reply Reply Quote 1
        • C Offline
          Clausj @VectorStyler
          @VectorStyler Great!
            @Clausj This issue should be fixed in build 1.1.072
            C 1 Reply Last reply Reply Quote 0
            • C Offline
              @VectorStyler Good job! Seems to work as expected. Thanks!
