    • Polygonal spiral placed offset
      5432
      Works perfectly now, thanks.
    • Occasional inability to change the artboard color with toolbox tool
      5669
      @VectorStyler Looks like you were way ahead of me on this idea! I realized you add this in the newest build. awesome!
    • Windows build .61 - clone disappears
      6571
      Fixed.
      dragging the layer in layer panel
      4944
      @VectorStyler Yes, Improved a lot.
    • Point snapping to group broken
      11233
      @VectorStyler said in Point snapping to group broken: @Igull This issue should be fixed in build 1.1.062 Yes, definitely working now, thanks. Neil
    • Opening AI Document with embedded PDF
      8119
      @VectorStyler said in Opening AI Document with embedded PDF: @Igull This issue should be fixed in build 1.1.062 Definitely fixed now, works well ! Thanks Neil
    • Move Node Broken ?
      6317
      @VectorStyler Works a treat - thank you !! Neil
      Changing colors from gradient panel
      4416
      @Jayanta-Das Yes, this is a regression in the current build. Will be fixed ASAP.
      Shape builder tool bugs
      4640
      @VectorStyler Fixed. Thank you.
    • Show palette bug
      5207
      Fixed
      Stroke Width Panel, Randomize Profile Preview does not work
      3791
      @Subpath This issue should be fixed in build 1.1.062
      Calling the Panel "Adjust Profile with Mask, could cause a Crash
      5478
    • Applications shortcuts menu width spacing
      5334
      @Boldline This issue should be fixed in build 1.1.062
    • [Text typing] The enter-key adds a blank line between lines of text
      9925
      @encart This issue should be fixed in build 1.1.062
      Gradients, the node with the last fill color is no longer selected
      4223
      Unintentional change of the stroke width
      6491
    • T
      UI measurement issue
      • typeglyph
      7377
      @typeglyph Pica number formats should be supported now.
      oddity with the gradient for strokes
      4514
      Cloned Stroke no longer there after reloading the file
      3704
    • Cropping artboard issue
      5323
