      The Navigator popup window is empty
      5572
      @Pat This issue should be fixed in build 1.1.072
    • Open PDF Broken
      13577
      @Igull This issue should be fixed in the new build 1.1.072
    • Clicking a flyout click/tap target re-opens the flyout menu
      • Bones
      4760
      @Bones This issue should be fixed in the new build 1.1.072. It is fixed for fill style popups only. The behavior of toolbox popups did not change, for now.
    • Main menu behaviour inconsistent with OS guidelines
      • Bones
      5013
    • SVG file with gradient import issue
      • Bones
      4802
    • Layer thumbnail for new layer shows content from existing layer for a second
      4480
      Also noticed this, and wanted to note that this issue also occurs when switching between open files. Top level thumbnails display the previous file's thumbnails when switching between files and even when the parent layer thumbnails are refreshed, opening the child layers still maintain the previews from the previous file that I worked on.
    • Problems with minimising panels to bars.
      4980
      @encart Replicated on Windows, will be fixed ASAP.
      EPS compatibility with Illustrator that contains gradients
      • ash-f
      3100
      @ash-f Yes, this can be replicated. As a workaround, use PDF for now. Will be fixed ASAP.
    • Group snapping broken again ?
      13395
      @Igull said in Group snapping broken again ?: VS just gets better and better for me. I agree and keep saying this with every build release update! I still keep saying it redundantly because @VectorStyler deserves to know the hard work is appreciated
      Downlownload link for Windows version on buy page is wrong, remove .dmg
      • GRAW
      3518
      @GRAW Fixed! Page might need a refresh.
    • Pen pressure issue on Windows
      • b77
      8630
      @VectorStyler After setting brush to pressure in context bar and switch to pencil it remain as pressure.
      Different color slider
      3008
      @Jayanta-Das I will try to fix this ASAP.
      Shapebuilder somehow triggers save, and then the app crashes. (1.1.065)
      • Gremriel
      8129
      @Gremriel Got them! Thanks!
    • Corner editor leftover
      3131
      @Ingolf Yes, the corner editor thinks that it could add a corner there, but the shape is too smooth for that at that node. I will fix this ASAP.
    • Cusp to smooth extremes
      5492
      @VectorStyler said in Cusp to smooth extremes: @Ingolf I will try to find a better way to convert the node. Currently the length of the control handles is fixed and they are rotated to be smooth. Should the length be reduced? But I think that would not work in some cases. I guess I was a bit quick here, this is exactly where the corner tool is the right tool. Forget this request.
    • spelling error in preferences>Editing Options 2
      3549
      @Boldline Will be fixed in the next build.
      Layer renaming in Layer Panel dont work
      4118
      @VectorStyler found the workaround already
      After tracing on the top of a bitmap, I can't move the object &...
      5561
      @VectorStyler Thanks for the tip Renaming is not important at this stage, I just wanted to test some of the VS features. As I have encountered some issues each time I have initiated one "test project", I will wait for the next update to test again all these same functions again on w10 et 11 (and make a kind of personal roadmap/tutorial which I may post here if it helps those who would like to use VS) and continue using other features to pursue learning VS.
    • Distort Images via shape effects no longer selectable
      • Dazmondo
      4136
      @VectorStyler said in Distort Images via shape effects no longer selectable: @Dazmondo This seems to be a regression in the latest builds. The option can be selected in the Shape Effects panel. Will be fixed ASAP. Works great from the Shape Effects panel -
    • Saved files missing
      save problem missing files • • VectorWhiz
      21665
      @VectorWhiz said in Saved files missing: Weird thing is that the files also were absent in the location to where my backup system (Aomei Backupper) is supposed to write instant copies of the files Could be related to the automatic backup system. I will try to replicate this.
