    2. Features and Ideas
    3. Implemented Features
      About the Snap feature
      • hbalcic
      6777
    • Double click ruler to activate guidelines panel
      7409
      @vectoradmin It is
    • Hold Option key while clicking flip icons to duplicate and flip
      6316
      @Boldline This should be available in build 1.1.024
    • Selected Live Text just have an underline in the layer color?
      5256
      UI/UX Shape Effects Panel
      • abn5x
      21551
      @Juandab There's an 'Open in List' option to display all effect settings stacked inside the panel: Is that better? Or is it something else you mean?
    • Changing values in fields
      19531
      @encart, drag on the label next to the field rather than the field itself.
    • Picked color always available in Color Panel
      6899
      @vectoradmin said in Picked color always available in Color Panel: @Ingolf This is doable, added to the backlog. WHOAAAAA rubbed my eyes, already implemented, you a STAR!
    • Repeat shape around a centerpoint
      14261
      @vectoradmin Yes its fixed.
    • Snap to canvas centre vertically and horisontally
      22244
      @vectoradmin Fixed in latest build (1.1.010)
    • Snapping to the center
      16846
      Indeed fixed, yes.
    • Layer features when right clicking layer / object
      17565
      @vectoradmin said in Layer features when right clicking layer / object: @Ingolf This feature has been added in build 1.1.008 Also world class, thanks a lot!
    • Artistic Text tool request
      17602
      @vectoradmin said in Artistic Text tool request: @Ingolf The snapping issues have been fixed in build 1.1.008 There is also a new option Preferences -> Document Editor -> Shape Text on Frame Dragging to enable drawing artistic text without the modifier key (and with the modifier key draw text frame). World class, thanks!
    • Color indicator+selector in layers panel superfluous
      16971
      @Ingolf Layers panel layout is improved in build 1.1.008
    • Exclude Fully Saved and Open files from Auto Recovery?
      6287
      @Boldline This feature has been added in build 1.1.008
    • Clear recently opened files
      4906
      @Ingolf Understood
    • Quicker Access to Toggling Node Removal Curvature?
      8402
      @b77 @Boldline I think the best way is to have some Modifier+Delete assigned as a separate action for this. But then it will be separate from the regular delete action (if the shortcut is customized, these must be assigned separately).
    • Font Dropdown Default cursor Active
      10301
      @b77 Oh ok - that makes more sense now that you explained it. It wasn't obvious to me prior, but maybe that's just me expecting one thing and not realizing it worked another way. It's fine now as it is - it works for me - thanks for sharing that info.
    • Center up this part of the stroke panel?
      9522
      @Boldline Which 'doubling up of the settings' do you mean?
    • Usability tweak - move none closer to fore- and background color
      19339
      @vectoradmin And it is great, thanks!
    • Layer rename request and a bug
      7539
      Bug fixed and request implemented - very good, thank you!
