    2. Features and Ideas
    3. Implemented Features
    • Merge tool auto-closes open path shape
      3866
      @Boldline This can be added (back) easily. I have to check if it is in conflict with some other feature. By default I try to have each boolean operation to work on open shapes also, but some may not need to.
    • Less harsh information boxes
      7394
      @vectoradmin That is a big improvement for sure! Thank you for adjusting that. Reducing the amount of empty space and rounding the corners makes a big difference. I think it would be nice if those boxes could be much lighter in color but I know it's tied to the dark theme
    • [Rename Objects window] Cursor placed in the Name field
      4525
      @encart This should be available in build 1.0.055
    • Option to change the color of the offset path fill
      5008
      @Boldline This should be available in build 1.0.055
      Mousewheel zoom
      • Hens
      5429
      @Hens The default modifier key assignment on Windows should be as requested in build 1.0.055 Also: there is Modifier Key customization option in Preferences (list on the left).
    • adding " to a number input box applies the input in inches
      3902
      @Boldline I added this to the backlog. It might have to wait till the expression evaluation in the number field is done (a requested feature).
    • Ability to move warp selection box before commiting edits
      4551
      @Boldline This should be working in the new build
    • Leveling / symmetrical arrangement of the generated polygons
      17864
      @encart @b77 @Gremriel Build 1.0.052 adds shape specific angle constraint when holding Shift. For example: when drawing a polygon, holding shift will snap the rotation to multiples of 180 / sides. This can be used to align a side of the polygon horizontally or vertically.
    • Is Automatic Backup in VS similar to what Affinity has?
      5275
      @Boldline Autosave is same as in AI, should save the file periodically. Autobackup creates separate backups in the selected folder.
    • Undo doesn't reproduce last steps in 100%.
      5743
      @vectoradmin You may have solved the problem as I haven't noticed recently.
    • Your ideas for improvement Boolean operations panel
      33
      33
      64318
      @vectoradmin Great!
    • Select color with eyedropper from within isolation mode
      13451
      @Boldline @Vector-Rock @b77 The eyedropper tool now draws the whole document with real colors even in isolation mode.
    • Image Trace Final
      5064
      @Boldline There is an Expand button in the trace panel now.
    • C
      Stroke profile live preview
      • cjochetz
      6352
      @cjochetz The stroke profile editing can be previewed now using the Preview checkbox at the bottom left of the modal view. Same goes for dash and stripe view also, in build 1.0.048.
    • Could we re-visit the auto sliding of the canvas when something is selected?
      6782
      @Boldline Auto scroll should work (when enabled) when clicking and dragging in an empty area for box selection. But it must be dragged outside of the view.
    • Function to change 1/10 of the set value by arrow key
      5607
      @vectoradmin Thank you for making this happen so quickly. It is very useful.
    • Make font search bar not case-sensitive?
      7041
      @Boldline The font search bar should work correctly in build 1.0.046
    • Toggle Guide lines alignment horizontally or vertically
      7080
      @Boldline This feature is implemented in build 1.0.046
    • Bracket keys adjust sizing of existing selected stroke/brush
      10049
      @vectoradmin Oh! ok that makes total sense now. Awesome. I like that setup.
    • Layer Options "preview on" by default?
      5274
      @vectoradmin that makes sense and that works for me
