About the Snap feature
Hello friends,
Is there an option to prevent Snap from being affected by other work surfaces? Or can we add such a feature?
Best regards,
Hakan Balcı
@hbalcic said in About the Snap feature:
What would those "other work surfaces" be?
Artboard 2
If I run the page diagonally in this way, it is not affected.
@hbalcic In the snapping panel menu -> Snapping Options (last) there is a "Snap to Visible Only" option that will limit snapping to objects that are in the view.
@VectorStyler said in About the Snap feature:
Suggestion for better naming here.
Wouldn't it be better to change "Snap to Visible Only" to "Snap to View Extend Only" or shorter "Snap to Viewport Only" or even shorter "Snap to View Only" ?
There is a big chance of confusion with the term 'visible' which is mainly linked to the layer system.
"Only Artboard" option can be added under the “Allow Snapping” option at the top.
@Ayo said in About the Snap feature:
There is a big chance of confusion with the term 'visible' which is mainly linked to the layer system.I added this to the backlog.
