    2. Features and Ideas
    3. Implemented Features
      Add a rotation handle to the selection box
      • postdes
      5341
      In the new build (194): selection box mode can be changed with the Preferences -> Adjustments -> Selection Box drop down. The Rotate with Knob mode will show a separate rotate knob handle for rotation.
    • VectorStyler App Icon
      8341
      @b77 that would be great!
    • UI Elements - Range Sliders
      • badcat
      6336
      @vectoradmin yup.. much nicer. thank you.
    • Closing the workspace-window
      • michaelokraj
      6820
      @vectoradmin said in Closing the workspace-window: In other apps the app is not closed when the main window is closed.
    • Artboards should be independent
      • matt
      5154
      OK, I've never used Illustrator so I will have to get my head around this concept. This is new and scary for me. I come from Freehand/Xara/AD route.
    • V
      Ability to Offset OPEN Paths and Create MULTIPLE Offsets of both Open and Closed Paths
      • Vector-Rock
      6740
      Some explanation on Offset Path and Contour: In VectorStyler, the Offset Path is a shape effect, an adjustment of the shape of the object (like the other shape effects). It cannot change the style of the object (stroke color or width). There can be improvements here in the new builds, but these will be limited strictly to the shape. The Contour effect is an object effect, meaning that it blends fills and outlines between selected styles. This can be improved in the future as suggested in the original post.
    • Suggestion for the Prefs: ✅ Menu animations on/off
      • michaelokraj
      6207
      What an improvment. I just tested a flow with some basic adjustments opening the menus: it is so much better (for the eye and also the nerves). THANK YOU very much!
    • "Live" Blend Modes
      • badcat
      7106
      That's a bit harder. Will think of a solution, without braking anything else
      UI/UX Redesign for ArtBoard Options
      • abn5x
      8338
      @vectoradmin Nice
      UI/UX Transform Panel
      • abn5x
      13928
      Build 165 brings a new UI style. The panel designs have been updated.
    • Flip Rulers
      • badcat
      9471
      build 160 fixes this, and several other issues regarding the ruler and coordinate system direction.
    • WEBP Format
      • badcat
      9155
      Fixed the flipping in build 159
      Too many decimals in text input boxes from Transform Panel
      • abn5x
      7478
      This should be fixed in build 147. number of displayed decimals can be set (per unit) in Preferences -> Number Editors section
      Dropdown Values UI/UX
      • abn5x
      11360
      The panning issue is still present in Outline Preview mode though. Anyway thankyou very much
      Multiple Panel Window Confusing UI
      • abn5x
      6124
      I see this one was fixed NICE!
    • E
      UI icons and some UX... :-)
      • ecouchez
      8524
      will try
    • E
      This "cheap" app icon please...
      • ecouchez
      4711
      Hi, I agree that the icon needs to be updated. Will look for a more suitable one, any suggestions are welcome
    • T
      Sample project
      • Tadengey
      6031
      @Tadengey hey... I'm with you. first day using it "seriously"... I'm overwhelmed with the myriad of configurations, options and features. If devs and UX designers are successful in balancing content and usability, this could be one of the biggest Illustrator predators.
    • C
      Move, scale, rotate, and skew key command (currently K)
      • cdnmoondog
      4651
      Will be changed
    • C
      Global kerning between letters of selected words by key command.
      • cdnmoondog
      7440
      C
      @vectoradmin Tracking does provide a solution, but it is a bit hidden and awkward to use often. Also, movement steps are a bit big (although this is something can be set to a finer setting?). Affinity Designer (who can drive me nuts sometimes) has the kerning controls between letters setup pretty good...once you have found it!!
