    2. Features and Ideas
    3. Implemented Features
    • Line Shape Grid Panel improvement
      8592
      @Boldline @encart This feature is available now in 1.1.002 (beta)
    • "Break apart" order
      4878
      @vectoradmin Great!
      A iterative saving option.
      5103
      @Subpath This feature is available now in 1.1.002 (beta)
    • Is there a way to know when stroke handle is aligned with stroke angle?
      14075
      @Vector-Rock Node shape customization is available now in 1.1.002 (beta)
    • V
      Calculate basic Math Operations and Convert Units in all numeric entry fields
      • Vector-Rock
      11759
      @Vector-Rock This feature is available now in 1.1.002 (beta)
    • sample colors from document for fill and stroke in context bar
      6115
      @Boldline There is a color sampling button now in the Color Panel.
    • Collapsed panels should stay collapsed when moved
      4865
      @Boldline This feature is available now in 1.1.002 (beta)
    • Clicking on Font name scroll-down menu puts blinking cursor in search box
      7410
    • V
      Faster pop-up speed of Description/Tips when Hovering with Cursor
      • Vector-Rock
      4144
      @Vector-Rock Tooltip delay option is available now in preferences.
    • V
      Improvements for Offset Path
      • Vector-Rock
      3818
      @Vector-Rock Most of these features are available now in 1.1.002 (beta)
    • V
      Option to Customize and assign each Node Type a Different SHAPE indicator
      • Vector-Rock
      4827
    • Double click preference
      14427
      @Ingolf said in Double click preference: @vectoradmin Question: panel options -> Isolate on control + click. On macOS I get the context sensitive menu? This affects the Layers panel only, if an object Control+Clicked in the panel, then it isolates that object (default behavior). If disabled, Control+Click will select the object both in the Layers panel and on the Canvas.
    • Saving Files when Quitting VS should correspond with visual of each open file individually
      4024
      @Boldline The Save alert, should bring forward the document it refers to. At least it does here both on Mac and Windows
    • Gradients - delete gradient stops directly
      5781
      Wild goose chase - it works. Ignore.
    • Brighter checkerboard and customisable color + size
      7005
      @Ingolf I will try to find a good solution for the preview background issue. You did! Options in beta 1.1 elegantly solved the problem. Thanks again!
    • Color dropper available everywhere - almost
      5793
      @Ingolf said in Color dropper available everywhere - almost: Many words, I hope I made myself understandable I do this all the time intentionally because I am always trying to be clear and leave no room for confusion
    • Keypad support - Apple Magic keyboard with numeric keypad
      5091
      @vectoradmin said in Keypad support - Apple Magic keyboard with numeric keypad: @Ingolf @encart I will add this to the backlog, there have been some bugs around this. The + and - keys may need to stay as they are (no differentiation for numeric keypad). Of course
      Please support Right To Left Languages!
      • webby
      22
      22
      39253
      @vectoradmin I would suggest you look at the SBL font that has the full set of vowels and other diacritic marks. If you have that font working, then everything else should work! They provide it as a TrueType font: https://www.sbl-site.org/educational/biblicalfonts_sblhebrew.aspx
    • Should the pencil tool default to whatever is in the fill and stroke panel?
      16114
      Awesome.
    • Improving Path Brush tool
      7381
      @vectoradmin Thanks for explaining all of that. I look forward to trying out the new settings for the path brush tool in the next build and I'll give you my feedback. On the topic of path brush location, it's interesting because you're thinking of it from a developer standpoint and I'm viewing it as a designer. I certainly do not claim to know the best place for it. I think it would make sense in a literal way for the path brush and vector eraser to be in the brush section, but I'd love to hear other thoughts
