    2. Features and Ideas
    3. Implemented Features
    • "Reset to Default" option in the Stroke width panel
      4178
      @Boldline There is a button for that in the Stroke panel (second for right). I can add it to the Stroke Width panel also.
    • V
      Better Image Quality of Cursor Icons
      • Vector-Rock
      12966
      @vectoradmin Indeed it has. Great!
    • V
      Change Stroke Display Field from 0.0 pt to Hairline
      • Vector-Rock
      9372
      @Vector-Rock @vectoradmin
    • Set default font
      5866
      @encart The problem is that the default character style now is inherited from the character style changes on a text selection (per an other request). So the only way to change the default character style is to select a text shape and change some of the character style options (font name, size, etc). The next (new) text shape or frame then will have this new style. This is also default style is saved with the document. I will have to add an option to choose between the above vs the default styles defined in the Styles panel.
    • Save button indicator
      4482
      what if it went from red to orange once clicked on while it's saving? then back to gray when done?
    • V
      Improve Resolution/Image Quality and allow User Customization of Tool "Cursor" Icons
      • Vector-Rock
      5702
      @Vector-Rock Cursor quality has been improved in build 1.0.045 and cursor size can be set in Preferences -> User Interface -> Cursor Scaling.
    • V
      Improvement to Default Object Properties Options
      • Vector-Rock
      4115
      @Vector-Rock Some improvements on default options are available now. The defaults are still set in the color (or other) panel, but they are not updated as objects are selected (Preferences -> Editing -> Update Default Styles)
    • Path Sketch - adding and subtracting
      4745
      @vectoradmin In build 1.0.045, the Path Sketch tool has an option to add or extract closed shapes.
    • V
      Snap Guidelines to Exact Ruler Visual Subdivisions using Shift Key & Drag from Ruler. Add Option to Snap Guidelines to Center of Artboard.
      • Vector-Rock
      11928
      @Vector-Rock Snapping multiple guidelines (selected or dragged from corner) should work in build 1.0.045
    • Methods to Modify Live Paths
      12819
      @Boldline I think the "Object -> Expand Clipped Groups" solves most of the above request.
      Interface improvements
      • postdes
      35
      35
      77446
      @postdes build 1.0.045 added flat themes on Mac
      Straight line mode for Pencil tool
      • postdes
      6883
      @vectoradmin Cool! Would be an idea to also use Tab to switch from object mode to node-editing mode? Hmm… everybody is used to A as the shortcut for that. Nevermind.
      Dotted dash lines (corner alignment and even distribution)
      • Arde
      10443
      @Arde This has been fixed in build 1.0.044
    • [Style Picker] Drag&drop
      8551
      @encart In version 1.0.044 there a style picker mode "Select -> Options -> Drag&Drop Styles" that will work as requested.
    • Improving the stroke alignment icons
      6357
      @b77 This has been implemented in build 1.0.044
    • Toggle Shape Editor & Transform Tool by using keyshortcut (A)
      5210
      @encart This has been implemented in build 1.0.044
    • Pattern Brush visual aide
      3506
    • Convert to Curves shortcut?
      4984
      Nice! sorry for the trouble - I thought I checked over all the icons already before posting . yikes... my fault. thanks for helping me find it
    • Red Dot UI
      4329
      @vectoradmin Thanks. My long time fog has lifted. It was my assumption that a single Red dot has many different properties. I tried to change the color and size of each in the preferences. When I expanded Node scaling, the colors became more visible and easier to use.
    • UI Style skin mode
      6434
      @vectoradmin (1.0.041) I liked the "Light Grey" mode the best. I'll probably keep using this mode. If possible, it would be nice to have a lighter dark on the dark side as well. On the other hand, in general: It's nice to be able to customize it to the user's liking. However, I think it would be better to have a default pattern as the identity of the app.
