    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
    • Laggy update of Color Picker in Context Bar on Windows
      • debraspicher
      4222
      Color Picker in the Context Bar has a tendency to change the position of a Hue (moving only on a rectangle area), I would like to change the hue myself. Also, I can't reach for the whole color spectrum compared to Color panel - video
    • Pencil tool fill adds stroke despite removing it in menu bar- endless cycle
      2577
      @Boldline said in Pencil tool fill adds stroke despite removing it in menu bar- endless cycle: but if I remove the stroke and then DESELECT and remove the stroke option in the contextual menu, it will still keep making new shapes WITH the stroke I removed I will try to fix this.
    • Tooltips are intermittent/slow to appear
      • debraspicher
      3378
      @debraspicher Got it, I will try to replicate with this workspace.
    • VS is Consistently Taking Up Massive Memory
      11312
      Memory usage here is much more slimmed down and certainly more efficient. Thanks!
    • Transform Origin with Move with Transform Origin doesn't work with Copies.. but Object Menu>Transform does...
      • debraspicher
      3455
      @VectorStyler I just posted this, it's related to your #1 point: https://www.vectorstyler.com/forum/post/25773
    • Imported Image Corruption
      • debraspicher
      3086
      @VectorStyler Yes, the issue I was having is it was reverting work and removing all Undo steps before that change after the revert. So I could not get back recent changes. This seemed to trigger really when I was Undo-ing much more frequently, for example, repeatedly laying down lines with the Pencil tool and playing with the Stroke panel to get a certain look. When I do another intensive document, I'll try to capture it in better detail. I have other footage, but I have to dig through it to make clips...
      Compound shape with a cloned object ?
      8066
      @VectorStyler Yes, that's right I'm mixing up different tests and trying to pass on an action...
    • Dragging many selected objects results in HUGE preview blocking everything
      • LoginError
      7121
      @VectorStyler Thank you so much! Version 1.2.029 is working perfectly. I tested it by freely moving over 100,000 objects in the Layers panel, and everything is functioning correctly.
      Crash occurs when deleting an object
      • Li Xiao
      2870
      @VectorStyler fixed. thanks
      Glyph dragged and dropped on the canvas can't be accessed by Text tool
      1979
      @Harry Yes, but this it not a bug. A glyph dropped from the glyph panel will be a "glyph" shape, a special kind of parametric shape, that has a single glyph as the attribute.
    • File>Import Single Click posts content outside of Clipping Mask
      • debraspicher
      2048
      @debraspicher I will try to replicate this.
    • Transform/Rescale works in unexpected ways when selecting Layer AND Objects
      • debraspicher
      1973
      @debraspicher Yes, here both the layer and its content are selected when resizing, resulting in that double scaling and movement. I will try to fix this by scaling only the top selected object(s)
      VS fails to change artboard orientation in Document Setup
      • William Kansepa
      5081
      @William-Kansepa said in VS fails to change artboard orientation in Document Setup: With an existing document, VS fails to change artboard orientation from Landscape to Portrait (but Portrait to Landscape is not a problem) through the Artboard section in the Document Setup modal view. This is only possible if I edit the artboard using the Artboard Editor. Note that this is an old bug. In VS 1.2.0.028 I am glad to say that this is now a thing of the past. @VectorStyler Thank you!
      Under the polygon lasso and magic wand modes, the magnifying glass tool fails and only the mouse middle button can be used to zoom in and out of the view.
      • monsterfox
      4476
      @monsterfox said in Under the polygon lasso and magic wand modes, the magnifying glass tool fails and only the mouse middle button can be used to zoom in and out of the view.: The magic wand function fails, and it is now just a normal selection tool. I opened a bug on this.
    • Layers Panel trashcan deletes text from Text on a path one character a time
      • debraspicher
      2336
      @debraspicher Can be replicated here also. Will be fixed for the next build. This happens only when the text editor is active.
    • Dragging to highlight numeric field for W,H in New Dialog is treated like scrolling behavior
      • debraspicher
      5100
      @debraspicher The "Scrolling Mode" settings determines how to handle swipes (scroll wheel) when hovering over a text field.
    • Can't rename Layers by clicking once until after opening Layer Options
      • debraspicher
      8540
      @debraspicher I will try to find out what can cause this and fix it.
    • {UX} Updating Stroke dialog behavior pre-selection
      • debraspicher
      4902
      @debraspicher Not for the stroke settings. The default for most of these is fixed to the basic stroke. The color, width and profile can be a custom default. In Settings -> Selection, disable the "Update Default Styles" and that will keep these defaults and not update them from the selection. But the other stroke options are not kept. I will try to improve this.
    • Document Window can't be undocked manually by dragging
      • debraspicher
      3288
      @debraspicher I will try to improve this.
    • A large preview accidently appears in layer panel
      4652
      @VectorStyler said in A large preview accidently appears in layer panel: should appear only when double-clicking on the small preview image Exactly. That's what I write If you by accident click twice on the layer ikon (instead of clicking twice on the name-string a few pixels to the east in order to change layer name), a large preview popup appears. Only way to get rid of it is moving the cursor outside large popup and click again. The latter part is especially annoying. To hide popup again I suggest a succeeding click anywhere should suffice.
