Imported Image Corruption
A few things:
Memory Mgmt is going crazy still, but we knew this from the other thread.
I noted that it seemed to go "off" when the Placed Image file "corrupted" itself in Layers panel and became "Stroke", "Object" respectively.
Neither of those elements can be duplicated in the file, when I tried.
Saved version of the file size: 45.3MB
Undo/Undo History is misbehaving somehow. It likes to forget History steps. In this file, I was trying to duplicate the Text Layers so I could do a Text to Curves and it "remembered" the version I got wrong with the path and text-to-path relations broken. I had to open an older file to get those paths back. I'm still creating clips for it.
I believe there might be a relationship with Undo history going poof and Layer corruption/Object mishandling...
Video: https://1drv.ms/v/s!AuWHX0h5bAoRio42uHDT7Lvh8_u-0Q?e=NKtBri
I will send some other files directly.
Update: I noticed "Ctrl + V" (Paste) is not working, however, I soon discovered I could Paste using the Edit menu. I tried to copy and paste those "Stroke" & "Object" elements.. it produces an odd hang in the application.
Vid: https://1drv.ms/v/s!AuWHX0h5bAoRio44y4GnOwT4BNthIg?e=rGK8g3
I go to produce the hang around 1:08
@debraspicher I will try to replicate this. The memory issues are already fixed (will be released soon).
History has a limit of 128 changes by default, but can be set in the Document Setup.
I'll get back soon with more.
@VectorStyler Yes, the issue I was having is it was reverting work and removing all Undo steps before that change after the revert. So I could not get back recent changes. This seemed to trigger really when I was Undo-ing much more frequently, for example, repeatedly laying down lines with the Pencil tool and playing with the Stroke panel to get a certain look. When I do another intensive document, I'll try to capture it in better detail. I have other footage, but I have to dig through it to make clips...
