    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
      After replacing the graphic, there is a deviation.
      • monsterfox
      3425
      @VectorStyler This problem has been fixed.
      Unretrievable graphic effects
      • monsterfox
      2755
    • Show selected problem while 'Show starting and ending nodes OFF'
      • Ayo
      2069
      @Ayo Got it, I will try to fix this.
    • Color Variations incorrect display color value first steps
      • Ayo
      2138
      @Ayo Yes, maybe the toning starts one step late. I will fix this.
    • Click and Drag to Add to selection is not working in new build 31
      2884
      @Boldline The problem can be replicated. I will release a fix today.
    • Doubling, tripling, etc, of interface after waking up PC from sleep
      • debraspicher
      4588
      @VectorStyler I'm also facing the same issue, but I didn't put my computer in sleep mode. I simply didn't close VS for a few days. This computer is one I occasionally use, and I never shut it down. After being away on a business trip for four days, I came back today and tried to open a file on this computer, only to encounter this situation. The OS is Windows 11.
      Image effect: "opacity" ? bug?
      5299
      @Pat said in Image effect: "opacity" ? bug?: I suppose that these two opacity-control sliders are not redondant ? Should not be.
      a bug
      • monsterfox
      2195
      @monsterfox Yes, can be replicated here also. In this case, reference objects must be expanded first (Styes -> Expand Symbol). I will try to add this to be done automatically.
    • Transform panel refusing coordinate input for guides on occasion
      • debraspicher
      4813
      @monsterfox said in Transform panel refusing coordinate input for guides on occasion: Please fix this problem. I opened a bug on this.
    • Color Panel + Spectrum mismatch causes Hue shift
      • debraspicher
      2362
      @debraspicher I will try to replicate and and find a solution
    • Artboards copy a 3rd Artboard and span the entire Canvas after unchecking of Artboard Coordinates
      • debraspicher
      3434
      @debraspicher There are also "export slices" in VS, can be used to mark an area of the canvas for exporting, and can include regions of multiple artboards.
    • Navigator View Presets are not working as expected
      • debraspicher
      3628
      @debraspicher said in Navigator View Presets are not working as expected: The shortcut, or at least I suspect it is the shortcut, for Switch Document View doesn't appear to work The shortcut is to switch between different views created with the View -> New View command.
    • Despite selecting a new Layer, sometimes it moves the Last Selected
      • debraspicher
      2823
      @debraspicher This is only a partial bug (in that sometimes it does not work), and that part will be fixed. The (existing) feature part is that if something is selected in the layers panel (strong blue highlight) and the key input is still on the panel (mouse last clicked in the list), then a shortcut action will be executed on the layers panel selection. For example, select two items in the Layers panel and press Control+G, it should group these two (not what is in the canvas), unless the user clicked away from the panel.
      Offset between a cloned object and contour after blending
      4614
      @VectorStyler Thanks for the feedback. No hurry for me. I report anything that can be considered a bug
    • Transform Selection Node Sizes Selector not working
      • Ayo
      2221
      @Ayo I opened a bug on this.
    • Page repositions or similar after some time minimized
      3697
      Might explain why the canvas always ends up offset for me.
    • Transparency Panel Dysfunction
      • debraspicher
      3200
      @debraspicher Got it.
    • Typo
      • Ayo
      2058
      @Ayo Will be fixed.
      Issue with the 'blend' object
      3069
      @VectorStyler Ok, file sent
    • Activating Node Tool when in Isolation Mode requires Layer selection
      • debraspicher
      4459
      @debraspicher said in Activating Node Tool when in Isolation Mode requires Layer selection: I was just curious if there was an alternative to access the other Isolation mode Only the menu commands. So maybe a shortcut could be assigned to these.
