    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
    • A large preview accidently appears in layer panel
      5393
      @VectorStyler said in A large preview accidently appears in layer panel: should appear only when double-clicking on the small preview image Exactly. That's what I write If you by accident click twice on the layer ikon (instead of clicking twice on the name-string a few pixels to the east in order to change layer name), a large preview popup appears. Only way to get rid of it is moving the cursor outside large popup and click again. The latter part is especially annoying. To hide popup again I suggest a succeeding click anywhere should suffice.
    • Cannot Select Elements in Layer
      • debraspicher
      4662
      @debraspicher This is a bug and can be replicate here also. The issue occurs when having layers inside groups.
    • Copy/Cut & Paste randomly not working
      • debraspicher
      3406
      @debraspicher Go to the settings / workspace file folder with the Help -> Reveal Workspace folder. Exit VectorStyler and backup / remove the settings and workspace files. When starting VS it will start with an initial state. Let me know if the issues persist here. Also, you could send me the backed up workspace / settings files (these do not contain personal info), so that I can try to replicate this issue (testing it on Windows 10).
    • Giant Grey Box when Moving Objects to Another Layer
      • debraspicher
      2312
      @debraspicher I added this to the backlog as a bug.
    • Cursor unsyncing/losing state when using tablet, especially with multiple Views
      • debraspicher
      3520
    • VS calculate numbers wrong
      3098
      @VectorStyler Affirmative. Works by eliminating the units. Also goes for "%"-box. Thanks.
    • Unable to sample the color from the artboard with the style picker
      2401
      @Boldline Try downloading again (no update), I added this fix a bit too late.
      About t if's two Bugs
      • monsterfox
      8476
      @monsterfox said in About t if's two Bugs: So now the problem is that black border I will try to replicate this problem.
      isplay has reached its limit
      • monsterfox
      2464
      @monsterfox Yes, the context panel can become large in some cases. There is a plan for customization in the future.
      Text selection presets have issues
      • Li Xiao
      4144
      @Li-Xiao said in Text selection presets have issues: Oddly, problem remains in old files Yes, because the old files do not contain the text selection info in the saved preset.
      Changing a 1st symbol modifies the arrangement of other symbols in a container (independent of the 1st symbol)
      4152
      @VectorStyler It seems that the issue is fixed
      Crashed when placed into a clipping group
      • Li Xiao
      3264
      @VectorStyler fixed. thanks.
    • Live text not able to change fill color, only stroke color can be edited
      2142
      @Boldline I opened a bug on this
    • Bucket Fill Tool issues with new update
      4465
      @Boldline Got it. I think the issue might be caused by undo. I will try to fix this.
    • Workspaces doesn't work for me
      • Dazmondo
      2335
      @Dazmondo send me the workspace file to csraba at vectorstyler.com
    • How to I get pdf crop marks without losing spot colors in VS?
      3660
      @Raaskot I opened a bug on this will try to fix the issues.
      Odd Bug
      • monsterfox
      2645
      @monsterfox This is an issue in the stroke expand. The stroke expand precision can be controlled using the zoom level. When zoomed in the precision is better, but results in more nodes when expanding. When zoomed out, the precision is reduced but it also results in a smaller number of nodes. What happens here is that in the zoomed out case, the stroke expand did not clean the resulting path correctly. I will try to improve this.
    • Transform>Coordinate Oddities
      • debraspicher
      4805
      @VectorStyler Thank you! It was crazy making. I didn't remember having this problem before
    • History panel does always not keep full history
      6540
      @Boldline said in History panel does always not keep full history: My expectation is that it would always keep an evolving list of the most recent steps up to the maximum set. Yes this should be the case. But it also depends on the hierarchy of previous undo/redo changes. I opened a bug on this to check if indeed the recent history is kept.
    • (Windows 10) Demaximize Doesn't Fully Register in UI when Title Bar Dragged
      • debraspicher
      3060
      @debraspicher This is a bug (on Windows), I will try to have a fix for the next build.
