    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
      About the concealed pallets
      • hbalcic
      3365
      @hbalcic said in About the concealed pallets: It does not hide the palettes inside the window. This is by design. It is only mean to hide floating panels.
      Abnormal path.
      • monsterfox
      2190
      @monsterfox The stroke is expanded because it has a width profile (small variation). If you open the stroke panel and click on the width profile editing button, you can see the width profile nodes. The clipping is an export option ("Clipped Export" in the export view), that can be disabled.
      The problematic text crashes when moved
      • Li Xiao
      2864
      @VectorStyler I forgot to check the appearance in text editor mode. now I understand. Thanks. I'll send the crash logs file to you.
      Outline Path, Shape Effect - very bad Bug
      2785
      @VectorStyler no problem anymore since the latest build 1.2045
      Offset tool shows a lot of history records
      • monsterfox
      5826
    • Node scaling not working/intermittent
      • debraspicher
      8698
      @VectorStyler Yes, I think that is perfect. Thank you!
      UI Redraw / Refresh Problem - Docked panels missing
      • MWK
      8884
      Hi: @VectorStyler said in UI Redraw / Refresh Problem - Docked panels missing: @MWK This issue should be fixed in build 1.2.038 Thanks for fixing this and the assistance. The new version fixed the problem. Regards, MWK
    • Toolbar Groups unresponsive to clicks; Regularly having trouble opening the group flyout
      • debraspicher
      7083
      The flyout is easier to trigger now, so thanks for this.
    • Ctrl Modifier for Node Tool blocking data entry in Transform Panel
      • debraspicher
      3623
      @VectorStyler Thank you!
    • Style picker tool not working as epected on windows
      • LoginError
      12673
      @LoginError The alternate mode style picker tool issues should be fixed in build 1.2.038
      Mouse Wheel only "add" a Value
      2917
      @Subpath Uploaded a fix. But no version increase, so you must manually remove and reinstall VS.
    • Glitches in Transform tab
      6482
      @VectorStyler "other transforms already applied" -- makes sense, thank you Yet one should expect transformation always applies to the latest effect layer/state in the stack only (retaining the objects current visible appearance). "... the transform pivot selection is disabled". Cool, very helpful. Got it. Though I must confess, that the options in the rightclick-dropdwn confuses me with combinated layer groups and textframes. As occasional user (and user of other vectordrawing programs) one have to click and try quite a lot to get the right setup ie. when rotating shapes.
      Corner Panel, some Presets are broken
      2928
      @VectorStyler This function has been missing for 4 versions (033 - 036).Hope it can be restored as soon as possible.
    • Text on Path gets disconnected when cutting and pasting even when grouped
      2492
      @Boldline Yes, this is a bug. I will try to fix it as soon as possible.
    • Mouse Wheel variable scroll rate
      • debraspicher
      7315
      @debraspicher https://www.vectorstyler.com/forum/topic/3021/alt-scroll-wheel-creates-new-obcjects-while-changing-width-height-value-in-transform-panel/3 https://www.vectorstyler.com/forum/topic/1442/unpredictable-changing-the-value-by-dragging Hi. I understand what you mean. I have mentioned similar problems in the past. And in fact I am still experiencing them, but I have acccpeted them. It's just that each wheel on the mouse has this noticeable click. And this single click works like a single press of the arrow key. In VS, when scrolling through the project window, the mouse always reacts in the same way by moving it by a fixed specified value, but with number fields it is different - every few times the wheel has to make 2 such clicks to change the value. As if the application is doing the calculations and the rest from the calculations accumulate . I would like the wheel click to act like a button click, just like in other apps.
      SVG output error
      • monsterfox
      4514
      @VectorStyler Strange phenomenon, the browser is normal, and Inkscape is normal, but the AI is not normal. However, the paths without color information are lost, which is uniform.
      Crash when trying to save a blend imported from Illustrator EPS
      • Arde
      4820
      This seems to be fixed now in latest release 1.2.036 -- brilliant!
    • [ Text on Path]The offset value does not change to the opposite when the path direction is changed.
      2684
      @encart The way the text offset works is that the original pat is offset by the given amount and then the text is placed one or the other side of that offset.
    • Unresponsive up/down arrows in SVG Export dialog
      • debraspicher
      2250
      @debraspicher I added this to the backlog.
      Palette from image does not work as expected
      3427
      @VectorStyler thank you
