    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
      Repeater's shift issue
      • Li Xiao
      5550
      @monsterfox said in Repeater's shift issue: In Inkscape, only one of the shift options can be selected. yes, in this case the pattern gap is not show.
      Issue with the interface
      30
      30
      40824
      @B-Vs-V The iconified panel column width can be resized (to show the name). I have to replicate the icon not opening issue.
      Huion Kamvas 22 inch tablet Pressure
      • artsquirrel
      3964
      On Windows. I checked that setting and it worked better after that, thanks.
      A suggestion about alignment
      • hbalcic
      5955
      @hbalcic said in A suggestion about alignment: ‘Key Objects’ commands belong to ‘Distribute’. Wrongly linked to ‘Align Positions’ commands. Works with the ‘Space’ command. The "Key Objects" option should also work with the align positions
    • Guide elements flicker when Snapping is Activated
      • debraspicher
      4351
      @debraspicher I will reopen this issue (it might be difficult to replicate).
      Paragraph Composer
      • hbalcic
      5168
      @hbalcic I opened a bug on this.
      Canvas panel response time
      • hbalcic
      2219
      @hbalcic I will try to find a solution for this.
      A suggestion about the ‘Scale’ slider in effects.
      • hbalcic
      4598
      @hbalcic Were the effects enlarged by scaling the objects? In VS, the scaling is non-destructive and it is added on top top the effect parameters. The effect panel will show the original (not scaled) sizes.
      Tab Stop is not working.
      • hbalcic
      5576
      @hbalcic said in Tab Stop is not working.: There were many fixes, how did you manage to fix them in such a short time? Short answer: He's a coding genius! lol. Don't let his modesty fool you
      A few suggestions for text wrapping
      • hbalcic
      6137
      @hbalcic That wrapping mode is use to flow text around the shape but also inside the holes of the shape, when we have shapes with holes. This is not the case for a single circle.
      A suggestion about Copy and Paste.
      • hbalcic
      5848
      @hbalcic said in A suggestion about Copy and Paste.: It doesn't paste it centred on the visible part of the page. I will reopen this issue.
      Correction request about the pallet group
      • hbalcic
      3541
      I forgot to include the missing part of the palette group.
      Spaces between words
      • hbalcic
      6893
      @hbalcic The default "minimum" word spacing for justified text is changed to -20%
      Suggestion file related to Text Fill Stroke
      • hbalcic
      2715
      @hbalcic This issue should be fixed in build 1.2.046
      Recommendations on the Drop Capitals palette.
      • hbalcic
      2936
      Inserting the paragraph space above the text field
      • hbalcic
      3095
      Colour palette zeros after comma
      • hbalcic
      3081
      Cursor direction in text
      • hbalcic
      3229
      Boolean Operations...
      • hbalcic
      2341
      @hbalcic The context panel was reduced a bit at some point to allow for smaller screens by default. The commands can be found in the Object -> Combine menu, and can be added back to the context panel with customization.
      None Fill - %50 black
      • hbalcic
      3125
      @hbalcic said in None Fill - %50 black: Swatches This term was introduced by Adobe and copied by Affinity and it refers to a mix of color, gradient and pattern definitions. VS choose not to use this because in VS the palette is just a color palette, with only colors allowed. For other things (mix of colors, gradients, patterns, etc) you have the "Presets" in VS (and also the "Styles").
