Pencil tool fill adds stroke despite removing it in menu bar- endless cycle
If I create a shape with fill and no stroke with pencil tool and then continue to add shapes to the artboard, it works as expected. If I then add a stroke to the settings or add a stroke to the existing selected shape, future shapes will also have a stroke - this is also expected.
If I remove the stroke from the selected object - it will create new shapes without the stroke - as expected. but if I remove the stroke and then DESELECT and remove the stroke option in the contextual menu, it will still keep making new shapes WITH the stroke I removed!
Ideally, if I remove the stroke from the contextual menu while using the pencil tool, even when I deactivate any selected shapes on the screen, any new ones should reference the current settings of the fill and stroke, not retain the prior settings
Here is the file for the first video:
0_1718571260778_pencil tool stroke acivated loop.vstylerThis second video I made to clarify things further shows another bug I run into as well as another example of what was described above. The bug occurs at the 6 second mark and goes to the 13 second mark. I tried to remove the pink as the stroke by clicking on the "no stroke" swatch box and nothing changed until I closed the stroke panel I was accessing from the contextual men and it was updated then.
Here is the VS file for the second video:
0_1718571161552_pencil tool fill stroke issue2.vstyler
@Boldline said in Pencil tool fill adds stroke despite removing it in menu bar- endless cycle:
I will try to fix this.
