    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
    • Still annoying problems with exported pdf's
      10712
    • Render as Image creates graphical artifacts
      • LoginError
      3064
      Text decoration - overline
      3245
      Text Frame Option - Baseline
      4814
      half-tone bitmap distortion
      • monsterfox
      4198
      Or you test it yourself, use the AI software to copy a half-hanged net to VS and try.
      Toolbox items without icon
      • maarten
      4719
      Than I think it would help to block the possibility in the configuration menu to go this deep. so users cannot make this mistake and there's no confusion about it. Although this does not solve the other issue; that also single level folders don't have a default item selected and show no icon until you first select one tool inside. I would expect that there's always an item selected, also after firstly adding this group.
      Artboard name issue. Looks like gibberish
      • Paola_B
      3005
      @VectorStyler I changed the Artboard Label font as suggested, and it worked. By the way, I'm using a M1 Silicon Mac with Ventura 13.6.3. Thank you!
      Missing commands in appearance panel
      2422
      @Harry I will update the documentation (there are other changes also).
    • Viewport often blinks oddly
      2777
      @Raaskot Got it!
    • Splitting text into lines is impossible
      3943
      @encart For some reason the MSI installer kept the previous language file. I will try to find out why this happens.
    • Converting text to curves …
      • michaelokraj
      4665
      @VectorStyler said in Converting text to curves …: The content of a text frame is not converted to curves with the "Convert to Curves" command. This makes sense - I'm not usually using the text frame method so I can see why I never ran into this problem prior.
      Artboard Becomes Bigger in PDF Export
      • gotanidea
      5091
      @VectorStyler Thanks, I didn't know we had to change the option.
      There is an issue when using Blended Shape to create a Repeater
      • Li Xiao
      4227
      @VectorStyler Both have been fixed. Thanks.
      There is the issue exporting linked EPS format to PDF
      • Li Xiao
      6564
      @VectorStyler fixed. thanks
      Moving a group with a displacement effect to the back causes a crash
      • Li Xiao
      3287
    • Problems with text in layers panel
      • Devil Dinosaur
      3019
      Works fine on 1.2.018 Thank you for the quick fix
      Update to 1.2 DELETES ALL PRESETS without any warning.
      • MajorTom
      4005
      @MajorTom said in Update to 1.2 DELETES ALL PRESETS without any warning.: is there another folder with prestes? Yes, the local user presets are stored in ~/Library/Application Support/NumericPath/VectorStyler... folder You will find separate folders for 1.1 and 1.2
    • On windows "Isolate Group in Layers Panel" and "Add / Remove Selection in Lists" both use the modifier key of Control.
      • LoginError
      2663
      @LoginError said in On windows "Isolate Group in Layers Panel" and "Add / Remove Selection in Lists" both use the modifier key of Control.: This makes it isolate any object I'm trying to add to my selection Yes, there is a bit of a shortage of modifier keys. I will try to find better defaults.
    • Cannot unlock all layers in Object Menu
      2577
      @Raaskot said in Cannot unlock all layers in Object Menu: Is this by design? Seems to be a bug. It ignores layers and only searches for locked objects. I will try to fix this for the next build.
    • Isolating grouped paths –– no edit-select in viewport
      2636
      @Raaskot Yes, this is by design. There are two isolation modes (now in 1.2). In the old (double+click) isolation mode (Isolate Inside) the content of an object is edited, but the object itself is not directly accessible. For example, if we have a clipping path, and we double click, the content (clipped objects) are edited. This is true even if there is no content, as we can draw new objects inside an other object. There is a new isolation mode (Isolate Selected), that can also be assigned to the double+click in settings. In this new mode, the isolation is on the object (not its content), so the object is editable. Also: the Node tool does not need isolation to select inside a group. It might have issues selecting inside clipped groups, depending on the click location.
