    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
    • Perforance settings bugs
      • XRAY
      424
      Repeater's shift issue
      • Li Xiao
      6348
      @monsterfox said in Repeater's shift issue: In Inkscape, only one of the shift options can be selected. yes, in this case the pattern gap is not show.
      Issue with the interface
      30
      30
      44839
      @B-Vs-V The iconified panel column width can be resized (to show the name). I have to replicate the icon not opening issue.
      Huion Kamvas 22 inch tablet Pressure
      • artsquirrel
      4810
      On Windows. I checked that setting and it worked better after that, thanks.
      A suggestion about alignment
      • hbalcic
      6627
      @hbalcic said in A suggestion about alignment: ‘Key Objects’ commands belong to ‘Distribute’. Wrongly linked to ‘Align Positions’ commands. Works with the ‘Space’ command. The "Key Objects" option should also work with the align positions
    • Guide elements flicker when Snapping is Activated
      • debraspicher
      4945
      @debraspicher I will reopen this issue (it might be difficult to replicate).
      Paragraph Composer
      • hbalcic
      5778
      @hbalcic I opened a bug on this.
      Canvas panel response time
      • hbalcic
      2594
      @hbalcic I will try to find a solution for this.
      A suggestion about the ‘Scale’ slider in effects.
      • hbalcic
      5326
      @hbalcic Were the effects enlarged by scaling the objects? In VS, the scaling is non-destructive and it is added on top top the effect parameters. The effect panel will show the original (not scaled) sizes.
      Tab Stop is not working.
      • hbalcic
      6383
      @hbalcic said in Tab Stop is not working.: There were many fixes, how did you manage to fix them in such a short time? Short answer: He's a coding genius! lol. Don't let his modesty fool you
      A few suggestions for text wrapping
      • hbalcic
      6943
      @hbalcic That wrapping mode is use to flow text around the shape but also inside the holes of the shape, when we have shapes with holes. This is not the case for a single circle.
      A suggestion about Copy and Paste.
      • hbalcic
      6549
      @hbalcic said in A suggestion about Copy and Paste.: It doesn't paste it centred on the visible part of the page. I will reopen this issue.
      Correction request about the pallet group
      • hbalcic
      3972
      I forgot to include the missing part of the palette group.
      Spaces between words
      • hbalcic
      7875
      @hbalcic The default "minimum" word spacing for justified text is changed to -20%
      Suggestion file related to Text Fill Stroke
      • hbalcic
      3023
      @hbalcic This issue should be fixed in build 1.2.046
      Recommendations on the Drop Capitals palette.
      • hbalcic
      3326
      Inserting the paragraph space above the text field
      • hbalcic
      3546
      Colour palette zeros after comma
      • hbalcic
      3548
      Cursor direction in text
      • hbalcic
      3652
      Boolean Operations...
      • hbalcic
      2626
      @hbalcic The context panel was reduced a bit at some point to allow for smaller screens by default. The commands can be found in the Object -> Combine menu, and can be added back to the context panel with customization.
