    3. Resolved 1.2 bugs
    Resolved 1.2 bugs
    • Glitchy Navigator UI (when docked, being undocked)
      • debraspicher
      2676
      @debraspicher These can be replicated, I will try to fix them ASAP.
    • Layer thumbnail preview when dragging Layers
      • debraspicher
      2754
      @VectorStyler Working beautifully. Thank you!
    • Program window expands on Save (Windows 10)
      • debraspicher
      3115
      @VectorStyler I didn't think so either in this case, but good to check because a slight "pause" could be caused by a drive taking too long if it is bound to fail or experiencing errors. The other possibility I thought of was maybe the drive was waking back up, but that drive is almost always active from media being accessed or Onedrive updates. I'll try to get the intervals just to be sure that it is indeed backup. I have video of it happening intermittently, but have to dig through and find a session.
    • Math isn't consistently working in Transform Panel (especially anything decimal related -/+)
      • debraspicher
      2680
      @VectorStyler I will edit to readd the video link. I tried both methods (out of curiosity). I generally don't touch the unit text.
    • Strange box when scrolling through Keyboard Shortcuts
      • debraspicher
      3168
      @debraspicher yes, this can be replicated here also. I will try to have it fixed for the next build
      PostScript Type 1 errors in 1.2 (Windows)
      • Arde
      2524
      @Arde I opened a bug on this and will try to fix it ASAP.
    • Will no longer print
      • ambros
      9113
      @ambros said in Will no longer print: it might be that the file is corrupted or something ? Not sure, can you send me that file.
    • Show Grid Shortcut Key not working
      • debraspicher
      3984
      @monsterfox said in Show Grid Shortcut Key not working: @VectorStyler Alt+~ It can't be used either. Please repair it by the way Will do so
    • Guidelines Panel is a wee bit truncated at bottom of scrollable list
      • debraspicher
      2480
      @debraspicher I added this to the backlog.
    • Gradient Editor
      • debraspicher
      11955
      @VectorStyler Yeah I've been able to still work with it using the gradient line. Sometimes it "unmucks" the UI also and allows me to work with it through the Gradient Editor panel. But largely using the line now. The only "problem" I have with using the line is that when I do use the color panel fly out, it's sometimes blocking elements so I can't see what it is actually doing. That's the only real downside.
    • Export dialog is reporting output size as inaccurate and in decimels
      • debraspicher
      2185
      @debraspicher I will try to replicate this, and fix it.
    • Text error in Documentation
      2575
      The "crlt" key fails.
      • monsterfox
      4511
      @monsterfox I will try to add these.
    • Transform Panel UX
      • debraspicher
      2789
      @VectorStyler Perfect! Smallest:
    • Erase block still not erasing only selected shape
      3774
      @Boldline said in Erase block still not erasing only selected shape: What about adding an option for same-style? The problem is identifying the style. Could be the current color, but that will handle solid fills only.
      Error in mirror tool
      • monsterfox
      3427
      @VectorStyler This problem has been fixed.
    • Duplicating a group/Layer results in an offset
      • debraspicher
      4534
      @debraspicher said in Duplicating a group/Layer results in an offset: @Ingolf Seriously, thank you! I have no idea how that got changed. Might've moved when I was checking through options on the above setting. As he says, this is the default in VectorStyler, likely inspired (perhaps a bit too much) by Adobe Illustrator. The intention is probably to make it easier to see and select the new object in relation to the original. It disrupts my workflow significantly, and I find this behavior outdated, likely stemming from a bygone era. The world has duplicated billions of objects since this "helpful" feature was conceived. It is clearly evident in the layers panel on our high-resolution screens that we have added extra objects. In any case, I use duplicate most of the time to create an object I need to move horizontally or vertically a certain distance aligned precisely with the original, so I quickly disabled this behavior. The idea of duplicate is to create a copy faster than copy-paste, so placing objects somewhere I have to move them away from creates more work than copy-paste. For me. Personally, I think this is a behavior and setting that could be removed entirely to make the program easier to use and the preferences slightly less cluttered.
    • Color Palette > Global Color issues
      • debraspicher
      5294
      Just glad to be of help. Thank you for looking into these.
    • Layer panel sluggishness/non-responsive behavior
      • debraspicher
      5812
      @VectorStyler I did the wipe. Long story short, yes, the behavior is still occurring and no differences there: https://1drv.ms/v/s!AuWHX0h5bAoRio871zPyvvseBns5VQ?e=FBejHD Edit: Checking current WS folder contents only has a /resources folder in case that is of help: https://1drv.ms/u/s!AuWHX0h5bAoRio88ioaZnAAoeIhbvg?e=G6ACSk
    • Dropping Layer in an Expanded Layer ends up outside instead of inside
      • debraspicher
      2210
      @debraspicher This can be replicated easily, will be fixed ASAP.
