    • R
      TEXT OVERFLOW
      • rediguana
      3044
      @rediguana I can confirm that this can be replicated here also. A fix will be available ASAP. EDIT: meanwhile, as a workaround, the path on which the text is set should be extended.
      Artifacts on Gradient Mesh Gradients when zooming
      11607
      @Subpath Got it!
      Lost background canvas of program
      • SJStalter
      16938
      Yes i found it. Yesterday the Navigator panel was covering the critical part. I've resized it and now have my program background. Thank you so much!
    • [Solved] Problems selecting objects after divide operation
      6107
      Of couse. D'oh. That was the last sign, going to bed. And thanks.
    • Bevel is completely broken (Image effects - Stylize)
      24
      24
      37264
      Better in .058! https://www.vectorstyler.com/forum/assets/uploads/files/1661726850039-b2008ef1-9aa2-4418-8798-c62d4bee7698-image-resized.png
    • Unsmooth mesh gradient
      9718
      @VectorStyler Fixed in .058!
    • Exported EPS file from VS not opening in older Corel programs
      15167
      @Boldline said in Exported EPS file from VS not opening in older Corel programs: or maybe run a virtual machine. I might try the latter - we'll see. I'm not sure Adobe still activates their CS suites…
    • Path Brush not painting on top and not changing to current fill color as expected
      3010
      @Boldline Got the file, but cannot replicate it. See email
    • T
      Creating a new layer makes everything else disappear
      • tudor
      4553
      @VectorStyler said in Creating a new layer makes everything else disappear: @tudor This regression should be fixed now. It is
      The Panel of "Adjust with Mask " seems to be buggy
      3577
      @VectorStyler yes they can be changed I am used to panels keeping their settings. But I was surprised that this is the case even after a reboot. Since I can save prefs, I would like it better if the settings would be reset at least after a restart.
      VS in "un-usable" state e.g. Undo no function
      • MajorTom
      13515
      @tudor This issue should be fixed now, please let me know if it occurs again.
      This topic is deleted!
      • freggern
    • Can't print direct from VS
      • Dazmondo
      14846
      @Boldline Sorry this is a late reply -- I can now print to my Xerox Phaser 6180DN, providing its just A4 with no bleed - CMYK is pure, but can't get trim guides to work as expected or separations to print --- How do you get halftones to work?
    • Mesh editor stays active
      7684
      @VectorStyler said in Mesh editor stays active: @Ingolf This problem should be fixed in 1.1.049 Fixed in 1.1.050!
    • Adding a gradient with to a shape with a stroke
      5058
      @VectorStyler said in Adding a gradient with to a shape with a stroke: @Ingolf This problem should be fixed in 1.1.048 It is.
    • Custom toolboxes added to main toolbox
      10567
      @VectorStyler said in Custom toolboxes added to main toolbox: @Ingolf Toolboxes should not be able to dock into each other in build 1.1.049 Fixed, yes.
    • Current Tools in statusbar
      5704
      @VectorStyler said in Current Tools in statusbar: @Ingolf This problem should be fixed in 1.1.049 Fixed!
    • VectorStyler omits objects in a simple pdf-artwork
      7356
      @Raaskot This problem should be fixed in 1.1.048
      Rotation pivot placing in the center after rotation
      5231
      Right Click after selecting objects
      9848
