    • Right Click removes the selection. Multiple items highlighted in the context menu.
      7938
      @encart This problem should be fixed in 1.1.048
    • Expanded stroke changes its position
      8408
    • Stroke appearance
      • Devil Dinosaur
      4807
      @Devil-Dinosaur This problem should be fixed in 1.1.048
      Pen Tool bugs
      4038
      moving shape after applying mesh gradient
      3900
    • Entering an expression without a unit in the field results in an invalid position
      4798
    • Keyboard numerical opacity shortcut not working on Mac M1
      8066
      @Boldline This problem should be fixed in 1.1.048
    • Color panel slider issues - part 3 (color mode)
      6809
      @Ingolf This problem should be fixed in 1.1.048
    • Character Style Presets do not switch in the Character Panel
      • Victor Vector
      4888
      @Victor-Vector This problem should be fixed in 1.1.048
    • Rome-Kana-Kanji conversion cannot be done with the SPACE key.
      6421
      @861475_VctSt This problem should be fixed in 1.1.048
    • Unwanted artifacts in the history panel
      4086
    • two undo steps to return nodes to original location when using alignment panel
      4366
    • Restore minimized Window in two-monitor setup fails
      4038
      @Ingolf This problem was replicated and should be fixed in 1.1.048
    • Grouping items in an open file then copying and pasting that group into new file breaks grouping
      8470
    • "False start" with pen tool linked to "create shape entry in history panel
      5250
      @Boldline There were some problems around setting up undo. Right now, the Pen tool may leave a Create Shape item there, but only if a node is created. Let me know if this occurs again.
    • Selecting all nodes from closed path (Ctrl+A) does not allow to move them.
      9019
      Pos1 and End Key misbehavior (Win)
      5439
      @Subpath This problem should be fixed in 1.1.048
    • Bullet Labelling in Paragraph Options (issues)
      • Victor Vector
      3934
    • Text Frame Stroke Appearance Issue
      • Victor Vector
      6312
    • HLS Slider needs a black/white button fix
      • Victor Vector
      3734
