      Draw Behind inconsistencies (Windows 10 Pro with latest updates)
      draw behind • • William Kansepa
      4767
      @William-Kansepa This issue should be fixed in build 1.1.062
    • Color difference clipboard vs VS
      13344
      @Ingolf This issue should be fixed in build 1.1.062
    • Artboard mess when pasting object copied from artboard
      5047
    • Undoing creating canvas plus artboards does not reposition viewpoint
      3862
      No Text appears when Exporting as .EPS and import that .EPS
      5169
      @Subpath This issue should be fixed in build 1.1.062
    • Text sometimes switches to the prior typed word on the same live text path
      3527
      @Boldline This issue should be fixed in build 1.1.062
    • E
      Keyboard Shortcuts not working after switching to Text Tool
      • Eric Abraham
      7305
      @Eric-Abraham This issue should be fixed in build 1.1.062
    • VS frequently forces Artboard to center screen when working off to the side
      3757
    • Customization bugs
      3728
      @Ingolf These issues should be fixed in build 1.1.062
      Taskbar at top
      • Petar_MK
      3681
      @Petar_MK This issue should be fixed in build 1.1.062
    • Pantone palette not displaying proper colors in VS
      11931
    • Shift-X does not swap fill and stroke settings when the pen, pencil, brush, etc is selected but no line is yet started
      4525
      Pencil: not functionning with the mouse
      3424
      @b77 I'm not sure, can't tell. It would do this only with the mouse and not the pen ? Thanks for the tip. I'll try again tomorrow.
      HSI sliders bug
      • Petar_MK
      12512
      OK, thank you.
    • VS project lost all type editing and lost history as well when reopened
      4795
      @Boldline said in VS project lost all type editing and lost history as well when reopened: This is probably related to issues with the same file before a few weeks ago. I think there is a bug somewhere when working with spot / global colors. I will try to find this out.
    • Colour picker tool cannot be aborted
      2779
      @Ingolf Can be replicated, will be fixed ASAP.
    • Groups do not snap as groups
      7788
      @Ingolf I added this to the backlog. There are certainly things to improve in the options and how the indicators work.
      Regression in document tab Windows 10
      regression • • William Kansepa
      9402
      @VectorStyler Ooh, that explains it! Thank you so much.
      Document corrupts and artwork disappears (Windows 10 Pro with latest updates)
      • William Kansepa
      5316
      @William-Kansepa Got the file, it does seem to be corrupted, and there might be something related also to mistakenly showing CMYK in the title area. I will try to figure out what is going on with it, and recover if possible. Meanwhile, I recommend doing a clean install of VS and removing all user data from C:\Users<user name>\NumericPath\VectorStyler1.0\ Some local color configuration might cause this issue, but not sure yet what.
    • T
      Typography Panel Bug?
      • typeglyph
      8557
      @typeglyph said in Typography Panel Bug?: About the “defaults”. Two items here really. It used to be that when you started a program, Pagemaker, Freehand, Quark, Illustrator, Photoshop etc. before you opened any document to work on, you could set your programs’, preferences. Close the program and re-open it to see your changes as the new default for any new document you start. This is how it works in VS also. Including most options set in document setup, etc for new documents. More on defaults, for example why are the colour spaces defaulting to the “shitty” RGB colour space (sRGB) instead of some thing more robust and with a wider gamut of colours? I think that sRGB is a common color space, especially for design intended for the web. Of course it has a reduced gamut (web). When we teach about colour spaces we often direct students to use the Adobe(1998) colour space, and no longer use any of the CMYK or other RGB spaces. Not being an Adobe program, the Adobe color spaces can be selected if available in the OS or installed separately. But as an aside look at the construction of the word: de·fault. The word “de” is often defined as OF or demoting and the word “fault” often connotes a MISTAKE. So a program coder [programmer] who sets defaults rigidly is actually setting up the program to use mistakes. I tried to avoid as many defaults to be rigid. Most are configurable, even as some are not exposed to the user (i.e. can be easily added to preferences if needed). For fonts, the default (for now) is to keep the current enabled feature set from the previous font. So when a font (typeface) is changed, the feature set will remain the same (even if not supported), and must be selected separately.
