TEXT OVERFLOW
Re: Text overflow bug in shape text frame
I am having the same problem as reported by other users in the earlier thread. I cannot resize a textbox to fit all my text without distorting the current text.
@rediguana I can confirm that this can be replicated here also.
A fix will be available ASAP.EDIT: meanwhile, as a workaround, the path on which the text is set should be extended.
