    • the "interaction indicators" section of the preferences does not seem to have a dropdown for options
      3688
      @Boldline This problem should be fixed in 1.1.048
    • U
      Unable to paste snapshot
      • umauma
      6167
      @umauma This problem should be fixed in 1.1.048
      Composite Object Bugs ?
      9584
      @Subpath This problem should be fixed in 1.1.048
    • Transparency Mask Shape Delete Issue
      • Victor Vector
      5704
      @Victor-Vector This problem should be fixed in 1.1.048
    • Offset path places itself underneath one selected object, but not the others
      3731
    • Stroke option inside Offset Path Panel does not stay current
      3928
    • Guidelines don't snap to Grid
      • Victor Vector
      6135
    • Trying to paste a copied object often results in a prior copied selection being pasted instead
      4322
    • Copy and Pasting of Text on a Path Not working
      4564
      @Boldline Is this problem still persists?
      Context bar
      6457
    • Artboard Placement Y-axis issue
      • Victor Vector
      4386
    • Opening Illustrator files stops loading and eventually shuts down VS
      7771
    • Spacebar to pan around is not working consistenly
      5606
    • Pen tool .34 little distraction bug
      4262
      @Ingolf This problem should be fixed in 1.1.048
      Failing to access Windows taskbar
      • William Kansepa
      24
      24
      43083
      @William-Kansepa This problem should be fixed in 1.1.048
    • Keep selection is not working (regression in .30?)
      5561
    • .32 regression - draw above acts as draw below
      3609
    • Critical bug (.32 regression) - cannot close curves with pen tool
      10527
    • Pan with Spacebar seems to occasionally stop working
      3771
    • 0.33 Object > Simplify Path does not work.
      4421
      @encart This problem should be fixed in 1.1.048
