    • Can not duplicate/copy shape by selecting it in Layers panel
      6592
      @vectoradmin Sorry, I thought I wrote back in this thread. It's ok, but I wouldn't be able to unravel this mystery on my own. I just expected the behavior to be analogous to other applications. Now I know the rules.
    • Rotating using a custom pivot point.
      4494
      @vectoradmin Tested! Thank you!
    • V
      Boundary Command Issues
      • Vector-Rock
      3963
      @vectoradmin said in Boundary Command Issues: @Vector-Rock Could not replicate (1). Is the Preview Shape Combine enabled in Preferences -> Document Editor section? Yes, the Preview Shape Combine is enabled. Good thought on that. That certainly explains Boundary being viewable on the Artboard when clicking on the Icon. I'll keep experimenting to see if I can find any pattern of when issues are happening. . As for (2): this refers to the Exclude operation, bit the boundary. @vectoradmin, I follow you. Certainly not the most elegant way to handle it, but at a minimum you might want to put some type of Horizontal Separator line of demarcation between the Boundary Options and Exclude option. Maybe you will come up with a more cosmetically appealing way to set them apart.
    • V
      Crashes when closing multiple documents, after updates, other?
      • Vector-Rock
      4649
      @Vector-Rock It looks like I did not get those crash reports. If there are still around, they should be located in ~/Library/Logs/DiagnosticReports/ folder, with names starting with VectorStyler If there you find any, please email them to me.
      Adjustment does not export
      • Arde
      3885
      @vectoradmin A bit late, but this has been fixed, and and least for image formats and PDF it should work.
    • brush size listed not corresponding with changes to the brush size adjustments with keyboard shortcuts
      3409
      @Boldline This should be fixed in build 1.0.041
    • Tool tips does not show while using tablet pen
      3917
      @encart This has been fixed in build 1.0.041
    • C
      Copy as SVG doesn't work
      • chefender
      4313
      @chefender SVG is copied to the clipboard (if enabled in the Preferences) on Windows also. The regular WMF/EMF copying (for clipboard) is still open.
      Duplicate (Ctrl+D) only works once. (Windows)
      • Gremriel
      4520
      @Gremriel This should be fixed in build 1.0.041
      Program shortcut not updated
      • Petar_MK
      11466
      Yes, it is. Thank you.
    • Brush sizes clunky
      6277
      @Boldline The brush (and stroke) width adjustment issues are fixed in build 1.0.041. The bracket (or up/down arrow) keys can be used to adjust the width while in the Pencil or Brush tools.
    • Undo/ Redo issues
      8527
      @encart The break apart undo / redo issue should be fixed in build 1.0.041.
    • V
      Navigator Panel- Pan View “Hand Icon” not always Appearing at Higher Zoom Magnification Levels
      • Vector-Rock
      6990
      @Vector-Rock This is fixed in build 1.0.041. The additional issues reported in a separate thread will be fixed later.
    • V
      Inaccurate Trim “Precision” of the Eraser Tool. Improved Tool Tip.
      • Vector-Rock
      3981
      @Vector-Rock Trim precision of eraser (also trim and join) tool is better now in build 1.0.041. The other large zoom issue (reported in a different thread) remain open.
    • Rotate with Charactor Tool
      3834
      @vectoradmin The transform panel (and view) now supports the use of adjustable object center, by clicking again on the selected center knob, the selection disappears, indicating that the adjustable center is used.
    • V
      “Outline” Preview Mode: Turning Off Visibility is Not Hiding Individual Objects
      • Vector-Rock
      5010
      @Vector-Rock This issue is fixed in build 1.0.041
      Unable to select text with click drag mouse. (windows 10) (1.0.040)
      • Gremriel
      3868
      @Gremriel Uploaded a fix for this (and one other regression).
    • V
      Cannot Click and Drag out Guidelines from Rulers when Zoom/Pan/Rotate Tools are Active
      • Vector-Rock
      4024
      @vectoradmin said in Cannot Click and Drag out Guidelines from Rulers when Zoom/Pan/Rotate Tools are Active: @Vector-Rock Yep, this is by design. I will change it. @vectoradmin, Note sure of the intent of the original design, but a HUGE thank you for changing this. You just saved the sanity of an untold amount of people around the world, ha ha, ha
    • V
      Numerous Zoom, Zoom View Tool, and Navigator Panel Zoom Irregularities
      • Vector-Rock
      3689
      @vectoradmin said in Numerous Zoom, Zoom View Tool, and Navigator Panel Zoom Irregularities: @Vector-Rock The zoom slider will have a smaller limit as the maximum zoom, as it would be hard to control a value that large with a slider. About the other issues. At what zoom level these occur? I haven't kept track of the exact Zoom Magnification Percentages, but I know it certainly has been happening at very high (just a guess for now, but 10,000% +), and many times near, maximum level (100,000%). I've been trying some ultra high precision placement of Guides at the intersection of path segments, then try to cut those paths or add nodes at the exact intersection of the placed guides. These attempts have often been at 100,000%. Often failing or with glitches. I would suggest doing testing of many of these tools/features at 100,000%. You should encounter some of the problems. I'll try to keep tabs on more specific percentages going forward.
    • Swap Fill and Stroke
      4060
      @Boldline Was some object or text selected on the canvas? There are some issues with the color panel, the fix will be in the next release, but I'm not sure they are the same.
