Inaccurate Trim “Precision” of the Eraser Tool. Improved Tool Tip.
@vectoradmin,
I have noticed that after using the Eraser Tool tool Option of trimming/deleting segments (Eraser Tool->Hold Down Shift and Drag) that when Zoomed In to very high Magnification Levels, the path segment(s) cut are not exactly coincident at the Intersection Point.
Is there a Precision setting that can be set for this? If not, I think the precision should be improved.
.Improved Eraser Tool Tip:
The Cursor hover over Tool Tip for the Eraser Tool needs to be better worded to indicate its capabilities and options.Current Tool Tip:
"Eraser Tool - Erase parts of object shapes using the eraser tool"Suggested new Tool Tip:
“Click and Drag to Erase parts of objects shapes, Hold down Shift to Trim and Join endpoints at the intersection. Merge at Intersections if enabled in Context Panel”.
.FYI, I think updating/improving the Tool Tips is a User Interface enhancement that would go a long way in decreasing the steep learning curve of VectorStyler (but that topic is for a new and separate forum post).
@Vector-Rock The precision issue can be replicated. There is no settings for this, it will be fixed in the next build.
Any suggestions on tool tips are welcome
@Vector-Rock Trim precision of eraser (also trim and join) tool is better now in build 1.0.041.
The other large zoom issue (reported in a different thread) remain open.
