Program shortcut not updated
In "Windows > Start" menu there is only one shortcut. It can't be removed. I can only uninstall it.
@Petar_MK I think the main issue is there there might be two NumericPath folders in the Program Files folder.
Yes, there are. Which one is correct -- "NumericPath" or "NumericPath Oy"?
@Petar_MK NumericPath Oy
Thank you.
Now I deinstalled both versions, restarted the computer, download Vector Styler again, reinstalled it, restarted the computer again, and now I don't have the shortcut in "Windows > Start". Only on desktop.
@Petar_MK This could be a problem in the MSI installer, will fix it for the next build.
OK, thank you.
@Petar_MK This issue is fixed in build 1.0.041
Yes, it is. Thank you.
