    • Rotation angle resets to default when command-zero is used to zoom out fully
      2719
      @Boldline This is be easy to fix, but it will then change default behavior. Currently this is by design (default for zoom, pan and rotation). I will add an other action (maybe set to Command-0 by default) that only resets the zoom and panning to fit into screen
      How to use this tool?
      • monsterfox
      7216
      @monsterfox That tool should not be listed among the actions (something internal). The correct simplify path tool is in the toolbox (3rd tool group).
    • Y
      Questions about Puppet Warp tool
      • Yaoif
      2668
      @Yaoif Yes, it is called Elastic Warp. Can be added as a shape effect and then edited (similar editing as in Illustrator).
    • Good brush parameters for non loosing color after one stroke ?
      • ZATOPEK
      6330
    • compatilities betwen AFFINITYDESIGNER brush and VECTORSTYLER brush ?
      • ZATOPEK
      2430
      thanks for this information
    • How do I make copy/paste overwrite text work?
      2173
      @Raaskot I opened a bug in this, will get back soon.
      Best way to achieve this effect?
      • wbjp
      5062
      @VectorStyler and @Subpath, Thanks! I will try.
      Stutter
      • monsterfox
      2011
      @monsterfox I will try to find a solution for this.
    • Using Path eraser to divide a shape does not want to completely disconnect/ungroup the newly detached piece
      4285
      @Boldline yes, this seems to be an error.
    • Adjustment layer halftone affects more than just the artboard
      2333
      @Boldline It will render the whole visible (or exported) area. This is basically the whole layer, the artboards are just guides for printing / exporting (Same goes with any other drawing). Adjustment effects can be restricted to an area or any shape, by drawing an object, adding the effect ti the object (as a regular image effect) and turning the object into an adjustment layer (in Object Options)
    • How do I reset the settings of the eraser panel back to the default?
      7051
      @Boldline said in How do I reset the settings of the eraser panel back to the default?: It would make more sense if "default was listed instead of it always saying "custom". I will try to change this.
    • How to use the Settings linked files
      3362
      @VectorStyler ok I think I understand. The file gets stored here "behind the scenes" but we look for the custom settings found inside the folder(s) where we adjust the settings file and workspace drop down buttons in the context panel. makes sense now - thank you
    • 360° Conical and Spiral gradient
      • nocturnalYL
      2335
      @nocturnalYL There is a bug here, I will have it fixed by the next build and then it will be possible to have asymmetric color
      Resources Panel?
      • William Kansepa
      2926
      @VectorStyler It appears when AltGR + Z combination is pressed in my case. I'm using polish layout.
      Polygon tool - where?
      • jsampson45
      3595
      @jsampson45 your welcome No matter what is showing here this is the "Smart Shapes" Section i.e they could be further be editied via the Shape Panel The currently selected Shape will be displayed at the bar. Note this little Triangle on right here which always mean there are some more Tools
    • "Open Recent" list empty after updating to newest build
      2792
      @VectorStyler Yes - after I opened a file I had used previously and then saved the updates to it and then closed it and restarted VS, it now shows in the "Open Recent" - but none of the other files listed prior to the update are there
      Save multiple effects (as a style?) and apply them to an object
      4665
      @Pat said in Save multiple effects (as a style?) and apply them to an object: Object Style can be created using the (+) button in the Styles panel, that opens a style kind selection menu Please send a file with the object that causes this crash (there must be an object to create a style).
    • Export to .PSD
      • Kemelvor
      13647
      @Kemelvor Moho looks cool, seems also that it have an impressive Feature Set
    • Memory loss
      • Ayo
      6691
      @Ayo Yes, the cause is the number of nodes (not available as a setting). I will try to find some solution to show some nodes even for these cases.
    • VS does not currently update live text font when grouped when missing font is activated externally
      2773
      @Boldline said in VS does not currently update live text font when grouped when missing font is activated externally: Basically - is it possible to have VS update missing fonts despite it being grouped? Grouping should not affect this. I will try to replicate this issue, it could be a regression.
