      Panels do not save their position
      8329
      @VectorStyler Files sent
      Duplicating a Path Section - per manual, doesn't seem to work
      • pentool
      7793
      @VectorStyler said in Duplicating a Path Section - per manual, doesn't seem to work: @Subpath The 3 node limit is because of a conflict with an other feature, where the Alt+ with 2 node selection will stretch the section between the two nodes. understand, have no Problem with that, (just wondered) if i need it i will add a node if necessary and deleted it later on
    • R
      what file format from Shortcut Presets in vector styler
      • re
      3027
      @re said in what file format from Shortcut Presets in vector styler: adobe-illustrator-cs2.xml Can you send me this cs2 shortcut file by email to csraba at vectorstyler.com I only have AI CC, I'd like to check if these are compatible.
      A suggestion for numbers in the workspace
      • hbalcic
      2066
      Vector Brushes size doesn't make sense to me
      2546
      @VectorStyler thank you ...Currently the default brush size is the same as the default stroke size (which is 1)... Yes, that's what I suspected. But it's not a suitable size for vector brushes.
      closed path
      • monsterfox
      8490
      @monsterfox I assume that VS is not running when you edit the settings file. One other option is that you edited a settings file that is from a different VS version (maybe 1.1). One way to check this is to change some settings in VS, exit and check if the settings.xml file date has been updated.
    • Set Live Text to a specific Angle
      2556
      @VectorStyler Ahh! yes the transform panel angle works perfectly for this. No need to add it to the contextual menu.
      A doubt.
      • monsterfox
      2629
      @VectorStyler At present, there is no such thing as a VS file. I have been using Freehand for many years and often encounter this situation, so I am worried about it.
      Printing compatibility issue
      • Li Xiao
      14598
      @VectorStyler I've had that happen as well
    • Is it normal to be able to open more than one Layers panel?
      • debraspicher
      3648
      @debraspicher The extra panel can be opened from the Layers panel menu, It can also be opened from the Canvas panel by clicking on the icon in a canvas row.
    • How to use these by keyboard?
      • debraspicher
      2303
      @debraspicher Should work when a node is selected. But now it seems that on Windows it is in conflict with a zoom shortcut. I will redefine these in the next build (fix the conflict).
    • gradient for brush stroke disappear
      • ZATOPEK
      2678
      @VectorStyler merci pour l'information
      Older versions are also showing in Installed app list
      2088
      @Jayanta-Das Remove those. There have been (and still are) some issues with the MSI installer. I will try to find a solution for this.
    • Issues working with Pattern Brush and Bitmaps
      • debraspicher
      6558
      Here is a larger version of the brush resource if it may be helpful for the purposes of internal testing: @2x grass resource
      Dxf import
      • Steve Haley
      2070
      @Steve-Haley said in Dxf import: was led to believe that this version could directly import DXF files. There is no DXF support yet, and none mentioned in the documentation or website. DXF support is planned for version 1.3
      Does Vectorstyler support switching brush and/or color by switching to another physical Wacom pen? (Tool ID)
      • maarten
      5330
      Thanks for the info everyone. Just to clarify; I really would like to use this to switch brushes (in several software) (so not only to have having different settings like sensitivity curves in Wacom). Looks like this Tool ID feature to switch brushes is already possible with Wacom since 2017!! And at least available in software since 5 years ago (!) as seen in this video by Aaron Rutten of 5 years ago where he literally does switch two wacom pens to switch brushes and talks about this in the video below: youtube video
      Enhancing Workflow Efficiency in VectorStyler
      • jammessbol
      2301
      @jammessbol However, I sometimes find myself spending too much time on certain repetitive tasks. What kind of repetitive tasks? Some examples might help to find a good answer.
      Accidentally changing a value in an input field
      5012
      @Subpath Got it. this occurs if highlighting in a field that did not have the focus. I will try to find a solution for this.
    • Outline Preview auto-converts artboard to black and white - what if I want it to stay color?
      2197
      @Boldline Not currently. The outline preview will render white outboard. This can be added as an option to show the color.
