Unintentional change of the stroke width
Unintentional change of the stroke width (VS 1.1.059)
Often happens when copying a stroke with Ctrl+C, Ctrl+V
also by moving a stroke under other objects
via the set back button, saw it most by copy and pastunfortunately not really repeatable
but is happen oftenI think I have found some systematic
create a stroke copy it
change the stroke width from the copied stroke
then copy this stroke
ect ....with this procedure it often happens
@Subpath I will try to replicate this.
@VectorStyler said in Unintentional change of the stroke width:
tried it again
as i wrote before this procedure her could replicate itcreate a stroke copy it
....another Video sometimes later
but the same happen
it is also possible that it plays a role
whether a stroke has a profilebut there I am still unsure
Tested a little further and it does to happen more often
when I use a different profile with a stroke.The bug are happens less often when the stroke has
the normal "Rectangle Standard Profile"
@Subpath This issue should be fixed in build 1.1.062
