Cloned Stroke no longer there after reloading the file
While trying out some ideas with stroke and cloned strokes
I noticed that the cloned stroke was disappeared after
reloading the file. (only an empty object remained)The error seems to be repeatable if you do the following:
create a stroke
create a clone of this stroke
send this clone to the back of all objects
save the file
reload the file and the clone was goneAs long as you dont send the clone to the back
it is in the File. It disappears only when you send
the stroke to the back.
@Subpath Can be replicated, added it to the backlog as a bug.
@Subpath This issue should be fixed in build 1.1.062
