[Text typing] The enter-key adds a blank line between lines of text
https://recordit.co/KlzRxoOpcl
I have had a problem with this since .053
Occurs only in this application.
Isn't it something about the space between paragraphs ? I mean "enter" can change paragraph (with a specified space) while "shift+enter" just goes to the next line. It's common in a lot of software.
I just edited. Doesn't happen here (0.053 on mac)
@encart This bug can be replicated on Windows. Will be fixed ASAP.
...enter-key adds a blank line between lines of text...
can confirm this behavior, dont like it
I would like it better if Enter leads to the next line.
@Devil-Dinosaur said in [Text typing] The enter-key adds a blank line between lines of text:
i know such a behavior only in Mind Mapping Software
never saw this in Vector graphics
It is not uncommon for word processors and other software on the Mac to interpret the return key as starting the next paragraph and the enter key (numeric keypad) or shift+return as inserting a line feed within the paragraph.
One example of where a line feed might be preferred is when working with bulleted lists: a line feed would allow for vertical spacing within a bullet item, without actually adding a new bullet.
Thanks for the info.
Don't have that much to do with word processors
and probably that's the reason why I haven't seen
this kind of behavior so often
@encart This issue should be fixed in build 1.1.062
